I really tried this, and I have 3070 which has MSI mode enabled by default. and still no hope.mago wrote: ↑05 Sep 2023, 16:30turn on gpu msi mode + undefined
bcdedit:
tscsyncpolicy Enhanced
useplatformclock No
disabledynamictick Yes
and with Intelligent standby list cleaner ISLC
set timer to 0.5ms
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\kbdclass\Parameters]
"KeyboardDataQueueSize"=dword:0000003c
if not high-end cpu set 40dec
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\mouclass\Parameters]
"MouseDataQueueSize"=dword:00000014
I'm VALO pro, still can't figure out what I'm doing wrong or what is going on!
Re: I'm VALO pro, still can't figure out what I'm doing wrong or what is going on!
Well, this is weird, I went to this guy's previous video, and he said switch to 1600x900 to fix the issue, I did that and indeed the game felt much smoother and the kills are instant, instead of that delayed headshot animation/delayed killmark.
wow!
checked download link for quickboost and its says malicious is that false positive? https://www.virustotal.com/gui/url/6334 ... 4f8c9166c0Tiberiusmoon wrote: ↑05 Sep 2023, 14:08Try:
bcdedit /set tscsyncpolicy enhanced
Download https://github.com/SanGraphic/QuickBoost and click the following:
Enable Exclusive Full-screen & disable Xbox Gamebar.
Disable mouse acceleration.
- Tiberiusmoon
Ah false positive, the kurd link is from within the description but you can get the github download from the releses section on the right side.eropsy wrote: ↑06 Sep 2023, 04:23checked download link for quickboost and its says malicious is that false positive? https://www.virustotal.com/gui/url/6334 ... 4f8c9166c0Tiberiusmoon wrote: ↑05 Sep 2023, 14:08Try:
https://github.com/SanGraphic/QuickBoos ... kBoost.exe
To clarify: https://www.virustotal.com/gui/url/ac6d ... bb8372b612
Thanks for clarificationTiberiusmoon wrote: ↑06 Sep 2023, 08:13Ah false positive, the kurd link is from within the description but you can get the github download from the releses section on the right side.eropsy wrote: ↑06 Sep 2023, 04:23checked download link for quickboost and its says malicious is that false positive? https://www.virustotal.com/gui/url/6334 ... 4f8c9166c0Tiberiusmoon wrote: ↑05 Sep 2023, 14:08Try:
There was a few posts by the chief on a somewhat detailed overview of how the netcode is handled in the background and how shady it is.
I remember him mentioning wierd stuff like the match making balance essentially adds in "hidden" lag to you vs others, maybe in this case you're account has been flagged for it or something. This stuff is pretty shady.
Did this just start happening? I recently found my power profiles broke and kept returning to balanced, gsync turned itself on with no indication in nvidia nor the monitor. Game mode turned on by itself, and HAGS enabled itself. I found all this when I was testing different RAM timings. I think it's connected to a Windows update at the end of August, perfectly timed for the release of the CS2 beta.
2023 Esports Guide: forums.blurbusters.com/viewtopic.php?t=11799
Windows 10 Esports Guide: forums.blurbusters.com/viewtopic.php?t=10724
try this post __ viewtopic.php?f=10&t=12036
i use ram timing 1- 1.5 -1.5 -3.5 , xmp disabled or 2800
