Yes. With off I can feel input lag. Ultra feels snappier
low latency mode
Re: low latency mode
I usually play Valo, and for me, setting low reflex latency mode thing in-game to off, and actually set nvidia to ultra low latency. just feels more responsive overall.
Rog Strix Z790i - Intel 13700K - 4090 OC ROG Strix - 7200 Trident G.Skill - 1TB SK Hynix Platinum P41 - 1000W ATX3.0 Asus Tuf - 34'' Odyssey OLED G8 - FinalMouse Tenz S/Pulsar Xlite V2 Mini - Wooting 60HE - Sennheiser HD 560s - Shure SM7b - GoXLR Mini
LLM off = no limits (the game sets the queue size itself)
LLM on = 1 Frame
LLM ultra = 0 Frame (is like a real time pre rendered frame so its like) but if cpu is not fast enough to render frame "on time" to the gpu, then it result in stutter
LLM on = 1 Frame
setting this setting on or ultra, makes my pc crash/blue screen in csgo. Meaning i'm forced to play with it off.
My GPU usage with my 1080ti is only around 50 %(Native +very high settings), so it should'nt make a big difference anyways. Still annoying.
Sorry to destroy your bubble, but that's just wrong. Low Latency mode only helps in GPU bound scenarios. Thats when your GPU usage gets over 90%. Then Low latency On or Ultra will help. If your GPU is under 90%, both options won't do a Single thing. In fact, Low latency Mode can increase input lag while applying a FPS cap, if you are under 90% GPU Usage! Capping FPS either trough game settings or RTSS will cut off more ms then Low latency mode/Nvidia Reflex. Cap FPS until your GPU never goes above 80% and you have a better self made Low Latency mode
source?
*= currently owned
CPU: 5800x3d 102mhz BCLK
GPU: 3080FE undervolted
MOUSE: Endgame Gear OP1 8k
KEYBOARD: Wooting 60he
*= currently owned
https://youtu.be/7CKnJ5ujL_Q?t=333, row 3 and 4.
Its just important to cap the frame rate bellow 90-99% gpu usage. That's pretty much it.
For additional, small latency reduction: the Lower the gpu usage, the lower latency.
thank youDiscorz wrote: ↑06 Jan 2022, 16:48https://youtu.be/7CKnJ5ujL_Q?t=333, row 3 and 4.
*= currently owned
*= currently owned
