VG259qm vs MAG251RX vs AOC24G2ZU
JustPeterinanutshell
Re: VG259qm vs MAG251RX vs AOC24G2ZU
Post by JustPeterinanutshell » 15 Sep 2021, 16:09
Okay thanks. So i should just go for the VG259QM for playing CS/Valorant right?
Discorz
VIP Member
Post by Discorz » 15 Sep 2021, 16:58
27" model has lowest lag elmb, not 25".
I'd go with either MAG or VG279QM then. 27" if u don't mind slightly bigger pixels at 1080p.
But don't rush. Maybe someone else here can give you better suggestions or advice.
teo
Post by teo » 15 Sep 2021, 19:57
I'll throw it out there that if you're coming from 60hz, I'm not sure you're going to immediately notice the difference between any of the known-good 240hz monitors anyway. I think it's reasonable for the pricing of your region to play a big part in your decision because they're all going to feel like big improvements.
I had a vg259qm for a week or so and to my eye, it seemed pretty good. I fiddled with its black frame insertion mode and it was a huge improvement compared to my old dell s2417dg's BFI--playing around with testufo I could really start to understand the appeal. in valorant, though, I found it pretty difficult to appreciate the difference. it's possible that I'm more of a stare-at-crosshair player than I realize, or that I'm just not that sensitive to blur. I also value VRR because I don't always play esports titles that can push consistent >240fps, and quality VRR+BFI implementations are still getting sorted. I ended up returning the vg259qm simply because I didn't want to drop to 1080p for desktop/non-gaming stuff.
Post by JustPeterinanutshell » 16 Sep 2021, 05:13
Ofc i will not realize the diffrence between each 240hz monitor, because my brain will prob explode because of 240hz, but still it is a investment for a couple of years so i want kinda the best option for my use.
For working/coding a 1440p monitor would be better but im fine with using 3 monitors for it. And for the games i play i dont see the purpose of 1440p.
but the VG259qm was good in any other respects?
Post by JustPeterinanutshell » 16 Sep 2021, 05:40
Okay since the VG259qm is atm only 30 bucks more than the AOC where i live and the mag is like an extra 50 bucks to the VG, i go for the VG. I hope it is a good choice for my purpose ;)
Discorz
VIP Member
Post by Discorz » 16 Sep 2021, 06:42
Its a solid choice, don't worry.
One thing you should know about VG is that it has bad lag at fixed 60Hz-99Hz (e.g. 1920x1080@60Hz). VRR 60 doesn't have that issue. Other refreshes are very good.
Post by JustPeterinanutshell » 16 Sep 2021, 07:18
Who is playing fixed 60hz? If i go under 240fps in like a single player game(which i play not often haha) i go with g sync and it should be fixed?!
Discorz
VIP Member
Post by Discorz » 16 Sep 2021, 07:37
Yes. It shouldn't be a big problem because why use 60 when there is 280Hz.
Post by JustPeterinanutshell » 16 Sep 2021, 07:51
y thats what i mean. do u have any suggestion/thread how i can test if i got a good Panel? I heard a lot that IPS panels are kinda a gamble?
Discorz
VIP Member
Post by Discorz » 16 Sep 2021, 07:57
You can check for dead pixels and uniformity. VG has good uniformity. Better than MAG deffo.
