Persistence After image or ghosting ?
yuri
Post by yuri » 14 Jun 2022, 12:38
Hello, :D
I would like to know what you see when you look the yellow paint.
It's look like afterimage due to persistence but some other Say its ghosting i would like to know what is is and how to get rid of it.
Btw it run at 240fps.
https://m.youtube.com/shorts/4MdPd-wZIJc
Re: Persistence After image or ghosting ?
Post by Chief Blur Buster » 14 Jun 2022, 17:18
Yes, it's a form of ghosting/corona. See LCD Motion Artifacts. Try adjusting your Overdrive setting on your monitor.
Which monitor are you using?
yuri
Post by yuri » 15 Jun 2022, 00:54
Chief Blur Buster wrote:
14 Jun 2022, 17:18
Hello chief,
Well im using the pg279qm its weird because it is the fastest ips panel on the actual market.. :?
Discorz
VIP Member
Post by Discorz » 15 Jun 2022, 01:04
I see only stroboscopic effect and no corona artifacts.
Reference
Stroboscopic effect with no overshoot
Test OD 0.png (11.39 KiB) Viewed 1970 times
Stroboscopic effect with overshoot
Test OD 1.png (11.5 KiB) Viewed 1970 times
yuri
Post by yuri » 15 Jun 2022, 11:17
For me, it's persistence if i Flick my mouse fast, i Can see an afterimage because overdrive does not change anything.. even blur.
Post by Chief Blur Buster » 15 Jun 2022, 16:35
Yes, it may be that too --
Although LCD GtG and overdrive does change the overshoot effects, it does not completely eliminate the stroboscopic effect -- it's well explained at The Stroboscopic Effect of Finite Frame Rates.
Retina refresh rate (where no further humankind benefit is derived) is not until ~4,000fps at ~4,000Hz for a 24-27" 1080p display, and not until 20Kfps 20KHz for a 180-degree retina-resolution VR headset. Related reading is Blur Busters Law: The Amazing Journey To Future 1000 Hz Displays.
yuri
Post by yuri » 16 Jun 2022, 00:58
Does we need to cap framerate if we got frame pacing , frame spikes or frame skips? I mean if in 2seconds you got 200fps 140fps than 80fps does the variable overdrive Can follow like g-sync does or vrr overdrive can't apply an overdrive when frame drop too fast?
Because in Bad optimize games on ultra with no FPS cap you got a lot of frame drop and stutter and its impossible to stablize at 150fps smooth.
yuri
Post by yuri » 27 Jun 2022, 06:26
If it was stroboscopic effect , why the blue paint does not ghost like thé yellow one, and the overdrive is set to off in this vidéo...
What i am experiencing is a trail/Ghost behind any contrast object when i Flick my mouse fast, its not ghosting because if i move my mouse smoothly it not smear AT all
Even when i set motion Blur i still see this strange effect..
Here if you stare at the snow on the tree you Can clearly see an afterimage of what i see on ALL objects.
even with Blur overdrive g-sync or any kind of settings...
https://m.youtube.com/watch?v=7K8KQd9YD4o
https://m.youtube.com/shorts/RY-3it1WvTk
Does anybody Can help me ? :?
yuri
Post by yuri » 03 Jul 2022, 19:33
Still not resolve.... :cry:
