Hi everyone,
I hope someone can help me out as I'm a bit clueless in my current situation.
I'm using a 144Hz monitor (Asus VG259Q) and am quite happy with it, but I'm looking for an upgrade. I recently learned about response time etc. (thanks to Blur Busters) and tried the various overdrive settings on my monitor.
I was shocked to find out that I can play much better with the strongest mode on (100) than with the "slower" ones. Mouse movement feels much faster and easier. Also, I could track enemies much better which used to be more of a "guess" until now.
Don't know if it's pure placebo. Of course, the big disadvantage of overshoot comes into play now, and don't get me wrong, the picture doesn't look good but somehow everything feels more responsive, easier, and faster with the highest overdrive setting.
Right now I play mostly FPS games, uncapped, and get around 300-350fps (mainly tracking heavy games).
So is this an illusion, pure placebo, or what does help me here in this case? The faster pixels or less "ghosting"? (Of course, I have overshoot now but with the ufo for example as far as I've seen it still stands out better because the overshoot is purple and doesn't just have that blurry trail behind it. (But please correct me if I'm wrong)
Is there a monitor that can give me the same if not better gaming experience just without the disadvantage of overshoot? (240hz or maybe even 360hz)
P.S.: I also tried BFI on this monitor. The picture was a bit clearer as far as motion goes however, everything got much darker and my eyes had to strain more and somehow everything didn't feel as fast, responsive either, so I don't use this mode.
Thank you very much!
Why can I play better with highest overdrive setting and overshoot?
Re: Why can I play better with highest overdrive setting and overshoot?
A stronger overdrive generally means a faster response time, hence why you played better on the fastest overdrive. The issue is the disgusting overshoot.
VG258QM 280Hz TN (main)| XG2431 240Hz IPS | XL2540K 240Hz TN | XV252Q 1080p 280Hz IPS | XL2546K 1080p 240hz TN | AW2518HF 1080p 240Hz TN | XV240YP 1080p 165Hz IPS | XG2402 1080p 144hz TN | 27GL83A 1440p 144Hz IPS | XL2411P 144Hz TN | XF240H 144Hz TN
Ah, I see, thanks for the answer! Yes, overshoot looks really badBoomchakadah wrote: ↑06 Oct 2022, 02:18A stronger overdrive generally means a faster response time, hence why you played better on the fastest overdrive. The issue is the disgusting overshoot.
In this case, should I be looking for a monitor with the lowest possible response time? (For example, use RTings and filter by lowest Total Response Time)
Overdrive fastens up the pixel transitions, meaning:
- removes distractions of ghosting/better focus
- helps you see things happen earlier on screen/less latency
Some people will prefer advantages over compromises as they are more sensitive to one thing than another.
Ah ok, thanks for the explanation Discorz! You're absolutely right there.Discorz wrote: ↑06 Oct 2022, 06:20Overdrive fastens up the pixel transitions, meaning:
But are there screens nowadays where you don't have to make a compromise with overshoot and still get the same good, if not better, performance with the 2 advantages you mentioned? (Is that only possible with TN?)
Should I then look for screens that just have the lowest response time or does the refresh rate also play an important role? (Compliance)
