Hi All,
I am attempting to recreate the custom resolution specified in blur buster's guide, here: https://blurbusters.com/blur-busters-st ... s-monitor/
I am getting an error whether I try to create the custom resolution in CRR Utility or AMD's software.
Here is the custom resolution I am trying to copy: https://imgur.com/a/t0gG2Lm
Here is my CRR custom resolution with the error: https://imgur.com/a/xaOQJN8
Thank you for any help!
XG2431 Custom Resolution
Re: XG2431 Custom Resolution
U can make QFT resolutions with "vertical total calculator". Do so within new or existing extension block (e.g. CTA-861).jack_jw wrote: ↑26 Nov 2023, 14:32I am getting an error whether I try to create the custom resolution in CRU Utility or AMD's software.
Here is my CRU custom resolution with the error: https://imgur.com/a/xaOQJN8
Thank you! Good quick YouTube.
...Getting things ready for the XG2431 review.
WOO HOO.
Discorz is one of the "few" display reviewers that finally figured out QFT-assisted strobe crosstalk reductions.
Hopefully it will pressure more manufacturers to improve strobing in a more user friendly way, because I would love to see more plug-and-play QFT to arrive in displays.
