Back in 2016 I bought my first 144hz monitor the benq XL2411Z and everything was almost perfect.
The screen was perfect for my needs but since the only way of getting 144hz out of it is with DVI, I will not be able to connect it to my next graphic card...
So I'm looking for a newer one with at least the same specs or better.
The first thing I did was buying a XL2411P, thinking that it will be my XL2411Z but with DP...
Yea well that as this moment that I discover inversion artifacts and I hate it.
(I can't understand how a new revision to a product can be this bad compared to the original)
so now I'm sending back my XL2411P and searching for a new one, can you guys help me with that ?
to summaries, I'm looking for :
Code: Select all
Price: ~200€
Hz: at least 144hz
Panel type: TN
Resolution: At least 1920x1080
Response Time: at least 1ms GtG capable
inversion artifacts: NONE
Flicker free: Yes
Color/contrast: at least same or close to an XL2411Z
I can't see any topic speaking of inversion artifacts on that particular model and maybe if there is a little amount of inversion artifacts I could remove it by "underclock" it at 144hz i don't know if that the right word pls don't hurt me
If anyone has one it would be nice to let me know if it is the case.
Thanks you for reading me.
