Dell S2721 dgfa g sync refresh rate help
Hi everyone. Please tell me the owners of Dell S2721dgfa, what is the minimum refresh rate on this monitor when g sync compatible is enabled, I heard that it works up to 20 Hz, is it true?
Xl 2546
Re: Dell S2721 dgfa g sync refresh rate help
Displayspecifications.com says VRR range for S2721DGF is from 30-165Hz. These VRR values can be modified inside CRU (by ToastyX) to a number you want or to a number monitor can achive.
