I have a Asus ROG strix G713QE gaming notebook that natively supports 144Hz.
The problem is that I noticed it leaves a huge ammount of ghosting. I took a picture with a camera 1/200s exposure time (faster than the refresh rate) and are clearly visible more than 5 different frames.
Attached the picture and a video of the ghosting test.
I don't really know what might be the cause nor how to fix it, any help would be highly apreciated.
Pixel response time way slower than refrash rate
- video5904503361008307536.mp4
- (3.3 MiB) Downloaded 79 times
- DSCN6011.JPG (761.53 KiB) Viewed 5928 times
Re: Pixel response time way slower than refrash rate
Is overdrive on? That usually improves it at the cost of overshoot
Being it a laptop there is no screen menu accessible, I can't find anywhere if it's off nor how to turn it on.
Your laptop looks to have a slow IPS panel, almost as slow as VA. Here is a simple video but Im not sure if u have the option to change these settings. https://youtu.be/qL6HJWxjfQs?t=241. Trade off would be washed-out imbalanced image. Try nvcp color setting if u're using nvidia gpu.
