Was wondering if anyone else has gotten custom Hz to work on this panel? or custom res in general on ada?
Been trying to get 360.000Hz or 333.000Hz on this thing for better jitter and frame smoothness but I still cant even tweak in NVCP or CRU
PG27AQN + ADA
Re: PG27AQN + ADA
It’s DSC.
If you want to use things like DSR/DLDSR and custom resolutions, you’ll need to disable DSC (which will limit it to 240Hz) in the monitor OSD.
Displays: ASUS PG27AQN, LG 48C4 VR: Beyond, Quest 3, Reverb G2, Index OS: Windows 11 Pro Case: Fractal Design Torrent PSU: Seasonic PRIME TX-1000 MB: ASUS Z790 Hero CPU: Intel i9-13900k w/Noctua NH-U12A GPU: GIGABYTE RTX 4090 GAMING OC RAM: 32GB G.SKILL Trident Z5 DDR5 6400MHz CL32 SSDs: 2TB WD_BLACK SN850 (OS), 4TB WD_BLACK SN850X (Games) Keyboards: Wooting 60HE, Logitech G915 TKL Mice: Razer Viper Mini SE, Razer Viper 8kHz Sound: Creative Sound Blaster Katana V2 (speakers/amp/DAC), AFUL Performer 8 (IEMs)
Re: PG27AQN + ADA
Re: PG27AQN + ADA
You can try, so long as it's below 1440p, but no guarantees; 240Hz 1440p 8-bit 4:4:4 chroma maxes out the non-DSC/native bandwidth of DisplayPort 1.4.JediBrysen wrote: ↑21 Dec 2023, 15:51Can I do 250Hz without DSC?
Bottom-line is, don't buy a DSC monitor if you want to create custom resolutions reliably.
Re: PG27AQN + ADA
thats weird it says for 2560x1440 that 1440p 250hz is only 27.65Gbps and DP 1.4 can do 32.4Gbpsjorimt wrote: ↑21 Dec 2023, 18:21Unlikely, since 240Hz 1440p 8-bit 4:4:4 chroma maxes out the non-DSC/native bandwith of DisplayPort 1.4.JediBrysen wrote: ↑21 Dec 2023, 15:51Can I do 250Hz without DSC?
Bottom-line; don't buy a DSC monitor if you want to create custom resolutions reliably.
Re: PG27AQN + ADA
UPDATE: got 250Hz to work at 1440p and I can get 290Hz but its unironically less smooth than 250Hz bc of jitter.
If anyone with a 240Hz OLED could try to run 250Hz lmk if it works. I wanna have 0ms jitter
Re: PG27AQN + ADA
I was speaking generally. It depends on the monitor.JediBrysen wrote: ↑21 Dec 2023, 18:56thats weird it says for 2560x1440 that 1440p 250hz is only 27.65Gbps and DP 1.4 can do 32.4Gbps
In the PG27AQN's case, it goes 360Hz 1440p max with DSC on and 240Hz 1440p max with DSC off. I.E. it doesn't have a factory overclock with DSC off that can fully saturate DP 1.4.
That and just because DP 1.4 can support that maximum bandwidth on paper doesn't mean that literally translates in all cases.
A particular monitor's scaler (and whether the scaler is a G-SYNC module or not), the firmware, EDID, etc, can also influence how much and what custom resolutions at what refresh rates you can push.
Probably frame skipping due to unstable timings (use this test to determine: https://testufo.com/frameskipping).JediBrysen wrote: ↑22 Dec 2023, 02:28got 250Hz to work at 1440p and I can get 290Hz but its unironically less smooth than 250Hz bc of jitter.
That said, I don't personally play with custom resolutions myself, so I can't offer much more insight than that.
Re: PG27AQN + ADA
Its not frame skipping, this is the most fluid the panel has been since having it imo. 0ms jitter is so nice.jorimt wrote: ↑22 Dec 2023, 09:09I was speaking generally. It depends on the monitor.JediBrysen wrote: ↑21 Dec 2023, 18:56thats weird it says for 2560x1440 that 1440p 250hz is only 27.65Gbps and DP 1.4 can do 32.4Gbps
Re: PG27AQN + ADA
I was referring to this:JediBrysen wrote: ↑22 Dec 2023, 14:47Its not frame skipping, this is the most fluid the panel has been since having it imo. 0ms jitter is so nice.
If your meaning of "jitter" was something else in this case (achievable frametime/framerate, etc), it wasn't immediately clear.JediBrysen wrote: ↑22 Dec 2023, 02:28I can get 290Hz but its unironically less smooth than 250Hz bc of jitter.
Re: PG27AQN + ADA
Oh i was meaning jitter by mouse jitter sorry for not clarifyingjorimt wrote: ↑22 Dec 2023, 15:33I was referring to this:JediBrysen wrote: ↑22 Dec 2023, 14:47Its not frame skipping, this is the most fluid the panel has been since having it imo. 0ms jitter is so nice.If your meaning of "jitter" was something else in this case (achievable frametime/framerate, etc), it wasn't immediately clear.JediBrysen wrote: ↑22 Dec 2023, 02:28I can get 290Hz but its unironically less smooth than 250Hz bc of jitter.
