Small "fix" on Valorant desync issues
widow13
So I've been having issues like a lot of people in here with desync and stuff.
Worst experience I've had is losing easy kills or shooting people and when I'm 100% sure they are dead they shoot back and kill me and they've been hit for 40 or 80 damage, also dying behind walls and stuff like that.
I tried something different past few days.
I set my power plan on balanced instead of high performance and capped my FPS to 300.
I have a 240hz monitor right now because my 360hz is on service, I'd cap fps to 400 on my 360hz.
So everything feels better aiming/desync wise, I can shoot people and I never die in 1 second without having time to react and it sometimes honestly feels like I have forever to kill them.
Now don't get me wrong game feels extremely laggy,stuttery and worse input lag wise but when I play on high frames it feels smooth but at the same time extremely unplayable and "off"/out of sync.
Multiple Immortal 3 accounts last acts with inconsistent performance due to various issues, played promos on an Immortal alt account to test and you can see for urself.
Again game feels insanely bad and stuttery right now but at least it "works". Will continue testing mixed settings like having no frame cap on balanced power plan and see how it works.
d-unknown
Re: Small "fix" on Valorant desync issues
by caping your framerate you just lowered the gpu usage , it's why you feel less lag, you can achieve the same by uncaping the frame rate and enabling low latency mode
13n47
There's something wrong with how much lag compensation is applied(my previous posts I give an overview to this). At times I have also been able to fix desync by capping framerate(to 230 in my case). One particular match I noticed capping to 180 was even better, changing it back to 230 I felt it instantly go worse and uncapping made it waaay worse.
It's most likely a miscalculation somewhere in the netcode that messes up the timings regarding other player movement and the effective speed of hit registration. The lag comp can be fixed by manipulating ping, network buffering or framerate. It's annoying but impossible to get a consistent fix as the sweet spots are always different from match to match.
widow13
I do use low latency aka reflex in game and game is smooth but unplayable without frame cap.
The thing is there is actually more lag right now but the difference is that the game "works" when it's laggy.
Yeah it honestly feels like having a lot of frames/smooth game overall makes it feel like you have "weird smoothness".
Like mouse will feel a lot faster and imprecise, you'll get bad bullet registration, people will kill you in 0.1 sec and stuff like that.
Also I've read threads about people with m2 drives having issues with high performance plan before but I'm not sure about that, will give it a try again.
Been a long time since Immortal lobbies felt this easy, will keep experimenting around and see how it goes.
FalKeT
Hello !
Thanks for sharing this fix, I will give it a try
Do you cap fps (300) via ingame frame limiter or external limiter please ?
akylen
Tried with 144hz rivatuner locking at 200 , for me it didnt make a difference , but if it did for you , nicewidow13 wrote: ↑18 Jan 2024, 01:31So I've been having issues like a lot of people in here with desync and stuff.
widow13
You can try in game cap too but I think power plan played a big role here.akylen wrote: ↑18 Jan 2024, 16:19Tried with 144hz rivatuner locking at 200 , for me it didnt make a difference , but if it did for you , nicewidow13 wrote: ↑18 Jan 2024, 01:31So I've been having issues like a lot of people in here with desync and stuff.
Got 360hz from service back today, gonna try with it tomorrow.
widow13
It honestly sounds weird but 1 day the game will work fine and the next one it will not.
I found out that switching between high perfomance/no frame cap to balanced/frame cap or vise versa makes the game instantly playable.
Gotta be something with power plans for sure.
ptaylor54
Super late to this post but can't agree more. Something is odd in this game's code tied to the windows power plan and overclocking in general. I notice anytime I set XMP , overclock the CPU or GPU, or set high performance power plans the game itself feels smooth and snappy, but the enemies you face are all MLG pros, one-tapping every swing with god-like reaction time. Then when I turn it all the settings to stock suddenly enemies are human again and the game feels easy.
It would be nice if people were actually tapped in at riot and could either fix or explain the issues upfront so that we could tune our machines properly for the game instead of having to go on wild goose chases and placebo minefields in order to have the game not feel awful.
zen9292
Two years later and I’m in the same boat, even after riot moved the game to Unreal Engine 5. Same desync you guys describe. Enemies faster than Demon1 when testing in deathmatch, just to find out they’re gold-plats and sometimes even silvers! (Im Immortal 1). I’ve dived into pretty much all placebo landmines, so much to the point that I’m going schizo (rabbit hole of electricity input lag discussions).
What I find to relieve most of the desync is exactly what you wrote, balanced power plan + frame cap. Switching back and forth between high perf + uncap fps mid test in deathmatch and the range, I can clearly feel the mouse input difference. Without desync, the game has little hiccups but you have maximum precision and also time to actually strafe properly during duels.
The thing that peeves me the most is that this solution is not permanent, somedays, some matches desync will be so awful that you can actually see opponents shooting at your trail or where you were but when you die, your model gets pulled back. I am also playing on relatively low ping (around 30-40).
As of writing this, riot did a game update that completely messed up deathmatch (no enemy gun sounds and footsteps randomly). Makes you wonder what type of spaghetti code the valorant devs team is working with at riot. Strange thing is streamers and most pros don’t get this desync as far I’m concerned, so maybe we are just a drop in the bucket regarding this issue. Until then, I don’t think riot will ever address this or it’ll just make them look really bad (precise gunplay).
