only floaty mouse
LaZaR04
Re: only floaty mouse
Post by LaZaR04 » 22 Jan 2024, 04:45
RealTweaker wrote:
21 Jan 2024, 22:16
So obviously the problem is with BIOS. Since after flashing BIOS all the settings reset to default it just could've disabled/enabled back some option that affects your mouse, or the r0ach's version. If i was you i would try to test every possible setting in BIOS on/off. Make sure your HPET is turned on in BIOS though.
Try to apply these settings in BIOS (copied from Sweaty Gamer Club Optimization Guide):
These are very important to get right as they have a giant effect on system latency and PC performance. The guide covers settings related mostly to Intel CPUs, but you can find similar options for AMD ones too. Names for options may differ by motherboard brand/edition. Settings in the BIOS are usually organized by category, but may be all over the place - therefore it's useful to check every submenu.
Disable the integrated GPU - you will be using a PCIE one.
Disable integrated audio if you have a soundcard.
Disable all E-Cores - they add latency/microstutter, as well as inferior performance for most games (you can’t OC P-Cores as high). This can be done by setting the amount of E-Cores to 0.
P-Cores should be at maximum (enable all).
Disable Hyperthreading.
Set CPU Ratio Mode to “fixed” - and apply a static clock speed to the max stable MHz your temps can handle by setting the core multiplier.
Set the SA/Ring/Cache multiplier to max stable.
Disable Intel Adaptive Thermal Monitor / CPU Over Temperature Protection.
Disable Intel C-State support. Disable all displayed C-States such as C1E. We don’t want ANY power saving on our CPU.
Disable Intel Speed Shift / Intel Speed Step.
BCLK lock-on should be at 100mhz.
If your RAM supports a XMP overclock, set it to the max it can. Overclocked RAM results in better FPS and especially lows.
Disable Intel Virtualization / VT-D.
Enable Resizable Bar for your GPU.
Disable secure boot.
For more in depth BIOS modding, see Hidden Bios Settings, which explains how to use GRUB/SCEWIN to fully optimize it.
As r0ach said try to reverse to the exact same BIOS version you had, if not possible, you can try going to some PC service center, i believe there is some more advanced way of changing BIOS version. If again no luck - buy new motherboard lol :D
I would also advise to read this guide from Calypto
i tried some of these settings but some of them dont exist on my bios or they have another name
LaZaR04
Post by LaZaR04 » 22 Jan 2024, 04:47
r0ach wrote:
21 Jan 2024, 21:49
LaZaR04 wrote:
21 Jan 2024, 08:56
hello guys im lazar i suffer from floaty mouse in all games in windows also it i tried alot of things but nothing worked i buy this pc before 1 year it was good everything fine i update the bios and i got floaty mouse i tried to go back to old bios version but didnt work i was peak immortal 3 405rr valorant now ascendant 1 stuck i cant even play games like league of legends its so hard because of this problem i tried to play from my phone internet without the ethernet cable didnt work i tried to reinstall windows and tried custom os i tried different room also so i think there is some settings in bios i need to do i have (motherbaord prime b660m-a plus cpu:i12400f gpu:rtx3600 ram 16( and i dont have any problem like they see me first or anything i only have floaty mouse movement and its not on my head because alot of people tried to play on my pc and they notice that is so hard to aim and i tried like 10 mouses
I’ve tested all BIOS releases for several different motherboards and the common theme is that there will be something like 12 BIOS releases for each one and somewhere between 0 to 2 of them will have decent mouse movement while the others are just bad. You’ll either need to try and figure out how to flash backwards or hope they release a better one in the future (probably not likely).
yeah i tried 6 or 7 version newer than the version that made floaty mouse same thing
jc41
Post by jc41 » 25 Jan 2024, 10:08
For me, the Legacy USB support and the XHCI hand-off in BIOS did affect my mouse movement. Try turning them on/off and see if it helps. Additionally, USB 2.0 works better than 3.0 on my PC.
RealTweaker
Post by RealTweaker » 25 Jan 2024, 12:54
So you update BIOS and get floaty mouse, then what u do is not trying to fix BIOS but going down that EMI road? You know where that road leads bro? To asylum.
ahead
Post by ahead » 25 Jan 2024, 23:05
jc41 wrote:
25 Jan 2024, 10:08
This change makes no difference because for over 10 years, only USB 3.0 has existed in PCs. When USB 3.0 is disabled, USB 2.0 still operates through the USB 3.0 chip.
Post by Slender » 26 Jan 2024, 00:45
ahead wrote:
25 Jan 2024, 23:05
jc41 wrote:
25 Jan 2024, 10:08
mcs9990 pci-e card
ahead
Post by ahead » 26 Jan 2024, 01:57
Can you use Linux or FreeBSD?. I can help you verify my statement with an easy method.
kibii
Post by kibii » 26 Jan 2024, 06:29
Do you have the XBOX app installed in windows? Whenever I reformat this app stealth installs itself everytime. I recently discovered that there is a Riot client extension tied to it. Disable that extension and see if it helps.
Mr1991
Post by Mr1991 » 27 Jan 2024, 21:13
ahead wrote:
25 Jan 2024, 23:05
jc41 wrote:
25 Jan 2024, 10:08
If only it was that simple
