GammaLyrae
Post by GammaLyrae » 24 Jan 2023, 22:56
05 May 2022, 15:02
SEA_mukilteo wrote: ↑
05 May 2022, 12:32
19 Apr 2022, 23:24
18 Apr 2022, 16:23
Can I expect no ghosting 3D stereo image with quadro graphic card / stereo 3 pin extension connector/active IR shutter glass and this viewsonic XG270?
Personally I'd consider the ViewSonic XG2431 for even better zero-crosstalk results (using 120Hz with the VT2250 trick).
Make sure the 3D glasses are correct polarization (vertical polarization versus horizontal polarization). IPS is polarized 90 degrees differently from TN screens, so shutter glasses for TN screens won't necessarily work unless you rotate your monitor by 90 degrees to portrait.
Hello,
I had chance to test ViewSonic XG2431 with active IR shutter glasses(XPAN 105-IR-X1 / for general 3D TV).
The test environment are like followings:
- Prepared side by side green/blue image @120Hz(sView)
- Quadro RTX 5000 with VESA stereo 3 pin extension connector
- Set PureXP as "Ultra" in ViewSonic XG2431
Observation
- No blur image on each left/right lens of IR shutter glass
- No polarized issue, it was same as TN screens
Question
Do you know why no polarized issue on ViewSonic XG2431?
This is because XG2431 polarization direction is 90-degrees different from most TN screens. That makes it compatible with different shutter glasses, like repurposed DLP shutter glasses.
- Shutter glasses uses LCD shutters which don't work well with wrong-polarized light.
- DLP emits unpolarized light (compatible with all shutter glasses)
- TN emits polarized light (compatible only with certain shutter glasses)
- IPS emits polarized light 90 degrees different from TN (compatible with DIFFERENT shutter glasses)
So shutter glasses must be compatible with the LCD's polarization.
You can also rotate a screen between portrait/landscape to fix polarization compatibility issues, since TN and IPS are polarized differently. IPS polarization is apparently more compatible with DLP-glasses polarization, because LCD inside shutter glasses don't work well with wrong-polarized light.
You found one of the best kept secrets: Today XG2431 is one of the best tiny 24" 3DTV-compatibles ever released -- near perfect zero crosstalk with the 120Hz VT2250 trick in ToastyX -- then re-calibrated with ViewSonic Strobe Utility to hide the room-temperature-sensitive part of crosstalk (temperature of summer/winter can worsen 3D glasses crosstalk).
I found that XG2431 PureXP is compatible with most DLP-Link glasses, with a "DLP-Link emulator" that has a shutter phase adjustment. And then using 3rd party 3D players that uses sequential-frame.
Voila. Perfect 3D from XG2431 that is superior to most 3DTVs and even better than NVIDIA 3D Vision!
It's very hard to setup, but I've been thinking of creating an open-source adjustable Arduino DLP-Link emulator box. That can turn most strobed LCDs into 3DTVs. It requires adjustable shutter phase, to compensate for refresh-delay difference between LCD and DLP, but other than that, it works perfect to use DLP-Link glasses with many strobed LCDs.
I imagine it'd work great with VorpX (enables 3D in video games), to turn XG2431 into a 3D Vision clone, usable with any generic DLP-Link glasses with compatible polarization.
Actually, I'll post an open source prize pot for this.
Bounty prize offer: $200 USD paid to first forum member who can package a working open source VorpX + DLP-Link solution for ViewSonic XG270 or XG2431
Requirements:
- DLP-Link glasses (cheap at $10 each)
- DLP-Link emulator (simple arduino box, I recommend Teensy 4.0 since it supports 0.125 microsecond USB 8000Hz for accurate sync)
- ViewSonic XG2431 monitor
- Viewsonic Strobe Utility
This probably won't need any changes to VorpX, however, if any is required (to sync between the DLP-Link emulator arduino over a USB cable), that code also needs to be contributed as open source to the VorpX team as a possible VorpX plug-in.
Bonus: Adjustable shutter-open-length per eye, and adjustable shutter-open-phase (relative to VSYNC signalling over USB cable to DLP-Link emulator box from Windows D3DKMTGetScanline() to monitor VBlank events). That should make it compatible with almost all strobed monitors, assuming compatible polarization.
Saw this post linked to in another thread I was reading, and a project like this would also be compelling to use with the in-development "geo-11" software that replaces Nvidia 3dvision for DirectX11 games - it's designed from the ground up to be compatible with existing 3d vision fixes made by the community, while being able to output natively to a variety of formats - 3d vision (of course), SBS/TAB/Interlaced, even full resolution SBS for output to VR. Crucially, it remains a single frame stereo 3d solution, and (eventually) should work with AMD hardware (currently, some shaders do not compile correctly on AMD hardware, resulting in game crashes).
A project like the one you've put a bounty on, with potentially a little extra work, would result in a completely open source, hardware agnostic replacement for 3d vision that'd work on the latest GPUs (Nvidia or not), on any display of sufficiently fast response time / motion clarity.
Worth mentioning that geo-11 is a free open source alternative to 3d vision and doesn't require the use of VR hardware, and has the backing of the passionate 3d vision community that is still actively developing stereoscopic fixes for games new and old, for the most common rendering API in use (DirectX11). VorpX is still paid software that targets a different, primarily VR based audience.
Post by Chief Blur Buster » 25 Jan 2023, 00:48
Also, a third party black frame insertion driver in a Windows Indirect Display Driver, would help turn all the upcoming new 240Hz OLEDs into a 3D Vision compatible display.
The black frames are necessary with OLED scanout-based pulsing, so that you've got a completely black frame while the shutter glasses is switching eyes, and then a fully open frame by the time next OLED scanout begins. So because of the non-global strobing of OLED, 240Hz OLED + BFI would be needed to generate excellent crosstalkess 120Hz 3D Vision reborn.
Technically this would work on any non-strobed 240Hz display too; because you can skip strobing support when you use software-based BFI. So any 240Hz generic display could turn into a 60/60 ("120Hz+BFI") frame sequential display.
And if you wanted shutter glasses autoconfigure -- then two computer connected photodiode sensors can be put at top/bottom edges (one each, at top and at bottom), to autorecognize global vs scanout pulsing, and autoconfigure shutter phase / shutter pulse width, to get crosstalkless 3D automatically on any suitable 120Hz+ strobed display or any 240Hz+ display (if a software BFI Windows display driver is developed that emulates a 120Hz display mapped with BFI onto a 240Hz display). Or use SpecialK's built in BFI feature, with some minor modifications.
Voila.
Generic 3D Vision on virtually any "240Hz+" display, regardless of panel type and regardless of whether it can strobe or not.
kt1
Post by kt1 » 13 Mar 2023, 10:51
12 Jan 2023, 23:43
Without strobing, 240Hz OLED is ~1.5x clearer than 240Hz LCD due to OLED GtG being near zero.
With strobing, 240Hz LCD can still beat OLED.
Most people will increasingly opt for 240Hz non-strobed at OLED GtG pixel response speeds -- the combination is sufficiently motion nirvana for most people (i.e. people who use basic strobing rather than Custom PureXP or LightBoost 10% etc). Strobing fanatics will still thumb nose at OLED (for now).
ViewSonic is also releasing OLED too, so if you want to wait, there's that option too.
Now that being said, XG2431 supports Strobe Utility while XG270 does not. Just wanted to give you that heads up.
Greetings Blur Chief, ecstatic that our savior has returned. salvation is at hand.
What is the persistence (ms) of the xg2431 strobed at 120hz/240hz vs the new oled coming at 240hz (do these also strobe, bfi)?
Are there any hard metrics we should be aware of going forward to make decisions on oled.
How many years do you suppose OLED might overtake strobed LCDs for motion clarity. :mrgreen:
Post by Chief Blur Buster » 13 Mar 2023, 15:52
Here are some simple rules of thumb:
Currently, the OLEDs dont strobe yet. So XG2431 strobed beats OLED by a large margin at the moment.
However, if you hate strobing, OLED beats any LCD of the same Hz
Also, remember, strobing does not necessarily always have less motion blur than non-strobed, because it is all about pixel visibility time:
To say, it's possible to have an unstrobed 480fps 480Hz display (2ms pixel visibility time) have less motion blur than a strobed 120Hz BFI display using 4ms pixel flashes.
Brute framerate-based motion blur reduction (helped by DLSS and other frame geneneration tech) is the future, since real life does not flicker, and reducing motion blur without BFI is more ergonomic. But requires 1000fps 1000Hz to hit 1ms MPRT on a sample and hold display without strobing. By 2027-ish, this will be very realistic, especially if Epic adds 10:1 reprojection tech to Unreal Engine Version 6.
GPUs such as RTX 4090 can already do 10:1 reprojection, and thus we already have technology to turn 100fps to 1000fps. Give it a few years.
DropDead
Post by DropDead » 29 Jan 2024, 03:57
Hello everyone. I recently became the owner of this monitor. It looks amazing. after studying this topic a little, I tried to adjust the image. I will say that the monitor is connected via hdmi to the laptop. therefore, I am limited by the bandwidth of the cable. After that, g-sync doesn't work for me.
I'm testing the modes now:
Pure XP 240 Hz and pure XP off + overload 5,224 Hz (224 Hz supplied via nvidia color space 8 bits available)I tried to put 224hz 10bit through cru, but it didn't work out, I guess the HDMI cable is to blame
I play mainly cod and fortnite. What mode would you recommend for these games? The frame rate is approaching a stable 240fps in both games
Exvinp
Post by Exvinp » 26 May 2024, 07:37
[ISSUE]
You can change the color of your ViewSonic ELITE XG270 monitor LEDS from the Elite Display Controller program, but when you click on the firmware update it says your version is up to date, but when you manually open the monitor's settings (by the monitor controll buttons) at Display->PureXP you only see On/Off options instead of: Ultra/Extreme/Normal/Light/OFF
[RESOLUTION]
Long story short: You have a monitor from an old batch, give up, you not gonna manage to upgrade the firmware.
Long version: I tried everything since I work in IT. Using only hdmi/display port, using a different usb cable even when I was able to change the led colors of the monitor, using different PC. Opened a ViewSonic IT ticket (#375473) for the issue, asked for the firmware software itself so I can manually upgrade the monitor, asked for the exact version number of my current firmware or the location where I can check it, or traces I could analyze myself, created them even video where I presented the issue => They said no for everything, and no solution was provided. Most likely they know about the issue, but since it is concerining only few people they simply don't care about it. Since the monitor was purchased really early the guarantee expired when I was interracted with them. Do not expect a lot from a company where in a tiny PROD software they have misspelling at a main feature of the program: If you open Elite Display Controller->Display menu->PureXP's info text second sentence: "Please trun them off...". :(
The good news is that I have read the whole forum through so I can provide you a summary about its content:
Upgrade firmware issue mentions:
viewtopic.php?f=4&t=5998&start=370
viewtopic.php?f=4&t=5998&start=430
viewtopic.php?f=4&t=5998&start=540
viewtopic.php?f=4&t=5998&start=560
viewtopic.php?f=4&t=5998&start=570
viewtopic.php?f=4&t=5998&start=580
viewtopic.php?f=4&t=5998&start=600
viewtopic.php?f=4&t=5998&start=610
resolution proposition, which is not working: viewtopic.php?f=4&t=5998&start=620
viewtopic.php?f=4&t=5998&start=630
viewtopic.php?f=4&t=5998&start=640
Motion Priority (for games not more than 120 fps):
PureXP + 120Hz + VSYNC ON
Latency Priority (for games more than 120 fps):
PureXP + 240Hz/224Hz[custom Hz] + VSYNC OFF
clearness:
viewtopic.php?f=4&t=5998&start=520
224Hz + PureXP or 119Hz+VSYNC ON viewtopic.php?f=4&t=5998&start=600
custom resolution with utility program
240hz viewtopic.php?f=4&t=5998&start=540
119Hz viewtopic.php?f=4&t=5998&start=590
119Hz viewtopic.php?f=4&t=5998&start=710
[VERDICT]
It is 2024 when writing this post, OLED panels with their 0.03ms response time, more clear image, 240 or more HZ, higher resolution than 1080p are offering more, TN panels are coming to an end, OLEDS are taking over in the gaming industry.
I won't buy ViewSonic again, if you want to make sure select one of the leading companies: Asus / BenQ ZOWIE
My personal recommendations as of 2024 May:
_____
OLED:
ASUS PG27AQDM: 2560x1440, 0.03 ms, 240Hz
MSI MPG 321URX: 3840x2160, 0.03 ms, 240Hz
_____
TN panel (if you really want one):
ASUS PG248QP (switch ULMB2 on)
ZOWIE XL2586X Fast TN 540Hz DyAc™ 2 Gaming Monitor for Esports
BenQ ZOWIE XL2566K 9H.LKRLB.QBE Monitor DyAc+ Premium, OD: 12 (old, but gold, "cheap")
(remember there is no point to buy a 540HZ monitor when you don't have that much of FPS in the game)
_____
IPS:
ASUS ROG Swift 360Hz PG27AQN
BenQ MOBIUZ EX270QM 9H.LL9LJ.LBE Monitor
Hope it helped. ;)
gl&hf
Robbo99999
Post by Robbo99999 » 02 Jun 2024, 02:55
Hello All, was there ever a fix for the "bug" that created ghosting when using 224Hz custom resolution with Fastest overdrive when using monitor in Full Colour Control mode? I tried using both NVidia Control Panel & CRU to create the custom resolution but the ghosting still remains. As another user mentioned earlier in thread it's possible to remove ghosting by running panel in "Native" for the Colour Control, but I want to use Full Colour Control so I can calibrate the monitor. Apparently the sweetspot for this monitor to reduce motion blur is 224Hz and Overdrive on Fastest, but as I said I get ghosting with that, and in fact the ghosting occurs at all Hz with Overdrive on Fastest, instead I have to run it on Ultra Fast which is one notch down on the Overdrive.
SEA_mukilteo
Post by SEA_mukilteo » 08 Apr 2025, 17:17
05 May 2022, 15:02
05 May 2022, 12:32
19 Apr 2022, 23:24
18 Apr 2022, 16:23
Hello,
Observation
Question
Requirements:
Hi,
Thanks for your answer.
I agree with you that XG2431 with VT2250 trick in CRU then re-calibrated with ViewSonic Strobe Utility will work well for displaying almost zero crosstalk image for 3D stereo image however I am not still sure that this approach could be work as nVidia 3D vision because of the image retention as you explained in other thread.
I expect that there will be quite significant image retention (thanks to extended VBI) in a few minutes after displaying static images and it will make 3D stereo image worse whenever repeated.
I saw that you already explained how to eliminate or avoid the image retention however we have to consider two polarity images for each left(60Hz) and right image(60 Hz) so that that minimum refresh rate should be 240Hz.(My math calculation, Left(+)-Black(-)-Right(+)-Black(-)... and add one more black frame every a minute.
I understand that general active IR shutter glass works between 100-144Hz. It means that refresh rate in XG2431 should not more than this frequency. I guess this could be the problem.
Let me know if I misunderstand anything.
Post by Chief Blur Buster » 18 Apr 2025, 22:19
Update:
Try this app:
https://github.com/PHARTGAMES/WibbleWobbleCore
It can do 3D glasses on XG2431
Post by Chief Blur Buster » 18 Apr 2025, 22:20
08 Apr 2025, 17:17
Wrong -- it has nothing to do with extended VBI. It's because of the LCD voltage polarity inversion is synchronized to the BFI. Static electricity builds up. Technical explanation: Why Image Retention / Burn-In Sometimes Occur On LCDs
Fortunately, OLEDs are immune to this, as are odd-divisors (e.g. 360Hz LCDs with NVIDIA 3D Vision simulators), you need a six frame cadence (L-L-0-R-R-0, or L-0-0-R-0-0) as software based black frames are still needed, whether you do one or two between visible frames (e.g. variable persistence BFI at www.testufo.com/blackframes ...)
