Does "LFC" work on older RX560 cards?
I'm trying to enable LFC on my AMD RX 560, but can't see any settings in the control panel in order to do so. Does the RX 560 even support LFC, or do I need a newer graphics card for LFC?
				Boomchakadah
Re: Does "LFC" work on older RX560 cards?
Yes. You just need to enable Freesync.
 VG258QM 280Hz TN  (main)| XG2431 240Hz IPS | XL2540K 240Hz TN | XV252Q 1080p 280Hz IPS | XL2546K 1080p 240hz TN | AW2518HF 1080p 240Hz TN | XV240YP 1080p 165Hz IPS | XG2402 1080p 144hz TN | 27GL83A 1440p 144Hz IPS | XL2411P 144Hz TN | XF240H 144Hz TN
