hello, when using latencymon i have this issue with wdf01000.sys it has high DPC count in short time (600K in less than 10 min while idle).
Is there a fix for that ? thanks
wdf01000.sys high DPC count
jassine
- Capture d'écran 2024-02-17 170801.png (104.25 KiB) Viewed 12754 times
xShino
Re: wdf01000.sys high DPC count
For me it goes up just buy moving the mouse. So I thought that's normal.
yamaci1775
Mine is similar, 100k in 5 mins. Is this normal, expected behaviour?
RealTweaker
This is my results after 4:57 minutes
andreeeeee-
wdf01000.sys DPC count relates to USB (3.0) usage
Higher numbers should mean higher polling from your USB devices, not necessarily some driver problem
jassine
I just found a solution that worked for me. Downloaded Iobit driver booster, found some intel drivers were corrupted, updated all the drivers from there. Now, no more 600k in less than 10 min, it only increases when i move my mouse.
