EMI fix for system responsiveness leads to motion blurr
milkicow
Re: EMI fix for system responsiveness leads to motion blurr
Post by milkicow » 05 Mar 2024, 17:43
Guys it can't do nothing for one reason, i have just played on my fathers pc with my monitor was fine. Then i plug in this circuit. And then it's all like my pc... The blurry motion is on. Then i unplug it and it remains. I will try to reinstall windows xd. The idea of the guy who made the circuit was that you are not only on using the neutral. That is all i can say.
You can try it for yourself it's very easy to make but you will see the difference i promise. The whole system became more fast but the monitor got blurry. That's the effect and it remains
milkicow
Post by milkicow » 05 Mar 2024, 17:44
Please this is very interesting. Pay attention to this post pls ..
milkicow
Post by milkicow » 05 Mar 2024, 17:46
[email protected] wrote: ↑
05 Mar 2024, 07:02
milkicow wrote: ↑
04 Mar 2024, 13:21
here is the circuit i used that helped me.
Many thanks for your response!
What did you wanted to achieve with this circuit? This is simply a rectifier that is connected incorrectly.
Maybe I don't understand what you meant, but you're just cutting off a sine wave. What voltage do you measure between phase and N with the rectifier connected?
Wasn't my idea i just took it ;) the guy said that it does better so i just copied but i really don't know what we are achieving here.
milkicow
Post by milkicow » 05 Mar 2024, 17:48
Unreazz wrote: ↑
05 Mar 2024, 08:45
i don't get or understand the point there really and need some explanation here.
A diode bridge, also known as a rectifier bridge, is a circuit composed of four diodes arranged in a specific configuration. It is used to convert alternating current (AC) to direct current (DC). The diodes in the bridge circuit conduct current in one direction and block it in the other, facilitating the conversion of AC to DC.
like why do you want to put this on neutral and where exactly ? As for my understanding, this is the same what a PSU does. it takes AC power from the outlet and turns into DC to power your computer and that DC power than goes back on neutral to the circuit at all in the end.
So you want to convert DC into DC again ? im so stupid
I am also not too good at electricity. I guess i will have to figure out what i did in the end.
Unreazz
Post by Unreazz » 05 Mar 2024, 18:36
milkicow wrote: ↑
05 Mar 2024, 17:48
Unreazz wrote: ↑
05 Mar 2024, 08:45
Where did you attached this setup ? on the Powercord Cable ? Because i have no acess behind my socket or to my whole circuit break
milkicow
Post by milkicow » 05 Mar 2024, 18:43
Unreazz wrote: ↑
05 Mar 2024, 18:36
milkicow wrote: ↑
05 Mar 2024, 17:48
Unreazz wrote: ↑
05 Mar 2024, 08:45
I have a Power outlet extender, so i cut it and put it on the neutral cable. and then plug in the pc to it
https://media.discordapp.net/attachment ... height=676
like this
milkicow
Post by milkicow » 06 Mar 2024, 12:36
Guys this is getting crazy .. So i made a fresh windows install and this is what i've noticed: my screen was flickering with 60hz and it kind of felt higher than 60hz, so i put 144hz and the flickering was gone. Then i put 50 hz and my screen got BRIGHTER. I guess it ressonates with the AC of 50 hz! Here are some videos
https://cdn.discordapp.com/attachments/ ... 07916d036a& - 144hz photo
https://cdn.discordapp.com/attachments/ ... 2a28ad3aa9& - 50hz photo
100 hz makes no flickering on the camera but darker.
XDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDD
VID20240306194648.mp4
60 hz
(1.23 MiB) Downloaded 228 times
MegaMelmek
Post by MegaMelmek » 06 Mar 2024, 13:22
Its nice find out… That monitor behave realy strange i may be something with the 50hz freq for sure
MegaMelmek
Post by MegaMelmek » 06 Mar 2024, 13:25
milkicow wrote: ↑
06 Mar 2024, 12:36
Did you know on what faze your outlet is? L1 L2 or L3?
milkicow
Post by milkicow » 06 Mar 2024, 16:00
How can i check
