What is the lower BFI limit? Is 60hz possible?daviddave1 wrote: ↑12 Mar 2024, 04:09The 27" 480hZ 1440P ASUS OLED will have a backlightstrobing tech. See the https://www.youtube.com/watch?v=bjdJjPd ... QwOQ%3D%3D video with the ASUS USA guy. I am courious how bright the monitor will get in SDR. The ASUS USA guy do says something about gamers who like brightness ( like me) he says something like if you really like brighntess other monitor tech suits more. Guess we have to wait and see.möppeldöp wrote: ↑08 Mar 2024, 07:38You can of course compare Hz 480 on Oled vs 540 on IPS or TN. I can tell you that most likely the Oled will win this comparison.
However, if you put motion clarity into your consideration, BLS / BFI is by far ahead on IPS or FastTN. If you care about colors, go buy Oled, if you care about motion clarity for precise vision/aim go buy a Product with blacklight strobing.
I clearly believe the XL2586X with DyAc2 is superior over all other technologies (ULMB2 & OLED & OLED BFI).
New Zowie Monitor 540Hz XL2586X
Re: New Zowie Monitor 540Hz XL2586X
price went down to 999 dollar! https://zowie.benq.com/en-us/monitor/xl2586x.html
| Now: ASUS PG248QP 540Hz. | Past : VG259QM with the Qisda panel/PG27AQN/XL2566K
https://www.reddit.com/r/Zowie/comments ... 6x_for_eu/ Zowie says here EU will get a drop later in April
No price cut for EU it seems, how much was it in US previously?daviddave1 wrote: ↑26 Mar 2024, 14:02price went down to 999 dollar! https://zowie.benq.com/en-us/monitor/xl2586x.html
arround 1179$forcedreg wrote: ↑27 Mar 2024, 04:51No price cut for EU it seems, how much was it in US previously?daviddave1 wrote: ↑26 Mar 2024, 14:02price went down to 999 dollar! https://zowie.benq.com/en-us/monitor/xl2586x.html
Dave, I asked above, what is the lowest refresh rate their BFI will work at? (on the Asus OLED, NOT the Zowie double strobing mess?).daviddave1 wrote: ↑27 Mar 2024, 12:00arround 1179$forcedreg wrote: ↑27 Mar 2024, 04:51No price cut for EU it seems, how much was it in US previously?daviddave1 wrote: ↑26 Mar 2024, 14:02price went down to 999 dollar! https://zowie.benq.com/en-us/monitor/xl2586x.html
Sry for the later anwer. I have no idea what the lowest BFI possible will be on the ASUS OLED 1440P 480 27" Its still in the works.Falkentyne wrote: ↑28 Mar 2024, 00:42Dave, I asked above, what is the lowest refresh rate their BFI will work at? (on the Asus OLED, NOT the Zowie double strobing mess?).daviddave1 wrote: ↑27 Mar 2024, 12:00arround 1179$forcedreg wrote: ↑27 Mar 2024, 04:51No price cut for EU it seems, how much was it in US previously?daviddave1 wrote: ↑26 Mar 2024, 14:02price went down to 999 dollar! https://zowie.benq.com/en-us/monitor/xl2586x.html
Thank you.daviddave1 wrote: ↑28 Mar 2024, 08:38Sry for the later anwer. I have no idea what the lowest BFI possible will be on the ASUS OLED 1440P 480 27" Its still in the works.Falkentyne wrote: ↑28 Mar 2024, 00:42Dave, I asked above, what is the lowest refresh rate their BFI will work at? (on the Asus OLED, NOT the Zowie double strobing mess?).
It seems that u cannot disable DSC on this monitor... why use HDMI 2.1 then? My pg248qp does have this option. This will prob be a dealbraker for me...
As far as I know, you can switch to EDID 500HZ in the XL2586X OSD, which will disable DSC.
So this is optional: 540Hz with DSC / 500Hz without DSC.
