Harm to monitor using blurbuster utility?
imacat0
Post by imacat0 » 24 Sep 2014, 14:36
I was wondering if using the blurbuster utility will cause any harm to my monitor over time? Thank you in advance :).
Edit: Wrong utility.
Koldur
Re: Harm to monitor using blurbuster utility?
Post by Koldur » 25 Sep 2014, 02:01
It uses an option that is normal to use with 3D, so the answer is, it will not harm your monitor anymore than using it with 3D vision which your monitor is made for!
