BENQ XL2720Z 27" of goodness :) [Version 2 firmware is good]
Re: BENQ XL2720Z 27" of goodness :)
Post by Chief Blur Buster » 04 Jan 2014, 20:36
GitDat wrote:The price I usually pay for living on the bleeding edge :) Maybe I'll go 3 for 3 and they'll all be good! I'll definitely let you know though. Thanks, Chief :)
Please do! And feel free to ask others about them (give them the link to this page). I would like to know what other peoples' experiences are.
LogicElite
Post by LogicElite » 04 Jan 2014, 21:16
Ordered one on Dec 20th at Ncix. Will be delivered on Monday. I can't wait :) I lost my chance to order a 248qe gsync on overload computer..I hope not regretting gsync over motion blur reduction. Did you have any advice for the xl2720z following your tests?
Another question, does the Xl2720z use the same type of panel as the 2420te since I heard only good things about this one?
I'm looking forward to hearing from you guys.
Thanks.
Sent from my SGH-M919V using Tapatalk
erebuss
Post by erebuss » 05 Jan 2014, 13:24
Ok, so I was hooked on this monitor until I started reading some of the G-sync stuff on this site and watched the G-sync demo video from Nvidia that someone posted in another thread. How are early G-sync monitors going to compare to the XL2720Z? Also, with G-sync will I have to upgrade video cards? I'm running an Nvidia GTX 590 right now. I've been pretty patient waiting for this monitor so if we're going to be seeing G-sync monitors soon that are going to outdo the Z series Benq, I'm thinking that maybe I should just wait a little longer.
Post by RealNC » 05 Jan 2014, 13:33
erebuss wrote:with G-sync will I have to upgrade video cards? I'm running an Nvidia GTX 590 right now.
The 590 doesn't support G-Sync. The supported cards are listed here:
http://www.geforce.com/hardware/technol ... orted-gpus
LogicElite
Post by LogicElite » 06 Jan 2014, 20:02
Chief Blur Buster wrote:Heads up, since it's only fair I inform readers of Blur Busters. I recently discovered an issue in the firmware of the XL2720Z, and it appears that some monitors are shipping with this firmware version.
With this test:
1. Enable Blur Reduction
2. Go to http://www.testufo.com/blurtrail
3. Select Height -> Full Screen
4. If you see this below, your XL2720Z may have a strobe timing bug (strobe flash occurs too early):
I now have a beta firmware for my XL2720Z that makes this fixable, but I don't think the monitors currently shipping, contains this firmware.
Just received the monitor!
Really impressed by the refresh rate and OSD but a bit disappointed by the colors but since it's a TN panel I can't ask more. Previously I was on a Dell U2412m and I will keep it for work.
Unfortunately I do have the following light line as you posted earlier with the motion blur at on. I would be very interested by your beta firmware. Is there any way to have a copy? :)
I'll keep posted.
Thanks.
GitDat
Post by GitDat » 06 Jan 2014, 20:12
That's disappointing :( Motion blur reduction is the whole point of this monitor! lol. As well as the reason I bought mine. I really hope this is an easy fix :-|
Cougar Conquer 2 | MSI Meg Z390 Godlike | 9900K | NZXT Kraken X72 | 32GB TridentZ RGB 3600MHz | RTX 3090 FTW3 Ultra | Samsung 960 Pro NVMe M.2 SSD RAID-0 | Corsair AX860 | 3DMark Port Royal - 14204 | Windows 10 Pro 64-bit | Triple 32" Samsung CHG70 | Samsung CHG90 Super-Ultrawide Auxiliary
LogicElite
Post by LogicElite » 06 Jan 2014, 21:10
Yeah a bit disappointed for the motion blur bug but overall I really enjoy the monitor. The difference 60 vs 144 is amazing. I was really impressed by the fluidity in BF4. The screen is well built, it is important to install the drivers and the screen is really bright by default.. My eyes were burning for the first 30 minutes :)
GitDat
Post by GitDat » 06 Jan 2014, 21:14
LogicElite wrote:Yeah a bit disappointed for the motion blur bug but overall I really enjoy the monitor. The difference 60 vs 144 is amazing. I was really impressed by the fluidity in BF4. The screen is well built, it is important to install the drivers and the screen is really bright by default.. My eyes were burning for the first 30 minutes :)
Awesome :) I'm hoping to run BF4 @ 5760x1080 @ 75Hz w/ strobing (as bright as possible) and see how playable it is. Right now I have all settings on Low to be able to keep the 120 fps minimum with v-sync on. Hoping for Ultra settings at 75 fps min :) We shall see Friday.
Post by Chief Blur Buster » 07 Jan 2014, 12:31
You may see extreme ghosting along the bottom 1/3rds of the monitor, due to the strobe-mistiming bug -- at least until your firmware is upgraded.
I have to talk to BENQ about how they plan to handle the firmware situation.
GitDat
Post by GitDat » 07 Jan 2014, 12:33
Ugh, I just can't win. Nvidia Geforce WHQL drivers 332.21 just came out today and they still don't address the strobing in Surround problem. I really hope BenQ fixes the firmware ASAP. Will I never get to see BF4 in strobed Surround? :cry:
