bleya99 wrote: ↑07 May 2024, 06:43
Hyote wrote: ↑06 May 2024, 12:42
skkiNN wrote: ↑06 May 2024, 09:34
Hyote wrote: ↑04 May 2024, 13:13
Added some, changed some. There are still things I could share but I'd need to write a whole guide then.
Another question man (sorry for my english) i just entered all the commands via cmd like 1 week ago. What i have to do if i want now enter ur "edited" commands and adding some others? Arent they duplicated or something like that? hope u understood what i mean
You can add them as many times as you like, only the values will change. I changed most, so you can even compare them with your current registry values.
Hi, where are the values from the 30th of April update? Those worked best for me. Cheers
This is what I have saved out from the 04/26 list:
reg add "HKLM\SYSTEM\CurrentControlSet\Control\Session Manager\kernel" /v "MaxDynamicTickDuration" /t REG_DWORD /d "1000" /f
reg add "HKLM\SYSTEM\CurrentControlSet\Control\Session Manager\kernel" /v "MaxDynamicTickDurationSize" /t REG_DWORD /d "4294967295" /f
reg add "HKLM\SYSTEM\CurrentControlSet\Control\Session Manager\kernel" /v "MinDynamicTickDuration" /t REG_DWORD /d "1000" /f
reg add "HKLM\SYSTEM\CurrentControlSet\Control\Session Manager\kernel" /v "SerializeTimerExpiration" /t REG_DWORD /d "2" /f
reg add "HKLM\SYSTEM\CurrentControlSet\Control\Session Manager\kernel" /v "MaximumSharedReadyQueueSize" /t REG_DWORD /d "96" /f
reg add "HKLM\SYSTEM\CurrentControlSet\Control\Session Manager\kernel" /v "BufferSize" /t REG_DWORD /d "32" /f
reg add "HKLM\SYSTEM\CurrentControlSet\Control\Session Manager\kernel" /v "IoQueueWorkItem" /t REG_DWORD /d "32" /f
reg add "HKLM\SYSTEM\CurrentControlSet\Control\Session Manager\kernel" /v "IoQueueWorkItemToNode" /t REG_DWORD /d "32" /f
reg add "HKLM\SYSTEM\CurrentControlSet\Control\Session Manager\kernel" /v "IoQueueWorkItemEx" /t REG_DWORD /d "32" /f
reg add "HKLM\SYSTEM\CurrentControlSet\Control\Session Manager\kernel" /v "IoQueueThreadIrp" /t REG_DWORD /d "32" /f
reg add "HKLM\SYSTEM\CurrentControlSet\Control\Session Manager\kernel" /v "ExTryQueueWorkItem" /t REG_DWORD /d "32" /f
reg add "HKLM\SYSTEM\CurrentControlSet\Control\Session Manager\kernel" /v "ExQueueWorkItem" /t REG_DWORD /d "32" /f
reg add "HKLM\SYSTEM\CurrentControlSet\Control\Session Manager\kernel" /v "IoEnqueueIrp" /t REG_DWORD /d "32" /f
reg add "HKLM\SYSTEM\CurrentControlSet\Control\Session Manager\kernel" /v "DisableLowQosTimerResolution" /t REG_DWORD /d "1" /f
reg add "HKLM\SYSTEM\CurrentControlSet\Control\Session Manager\kernel" /v "XMMIZeroingEnable" /t REG_DWORD /d "0" /f
reg add "HKLM\SYSTEM\CurrentControlSet\Control\Session Manager\kernel" /v "UseNormalStack" /t REG_DWORD /d "1" /f
reg add "HKLM\SYSTEM\CurrentControlSet\Control\Session Manager\kernel" /v "UseNewEaBuffering" /t REG_DWORD /d "1" /f
reg add "HKLM\SYSTEM\CurrentControlSet\Control\Session Manager\kernel" /v "StackSubSystemStackSize" /t REG_DWORD /d "65536" /f
reg add "HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer" /v "AlwaysUnloadDll" /t REG_DWORD /d "1" /f
reg add "HKLM\SYSTEM\CurrentControlSet\Control\Session Manager\Memory Management" /v "DisablePagingExecutive" /t REG_DWORD /d "1" /f
reg add "HKLM\SYSTEM\CurrentControlSet\Control\Session Manager\Memory Management" /v "LargeSystemCache" /t REG_DWORD /d "1" /f
reg add "HKLM\SYSTEM\CurrentControlSet\Control\PriorityControl" /v "IRQ8Priority" /t REG_DWORD /d "1" /f
reg add "HKLM\SYSTEM\CurrentControlSet\Control\Session Manager\Memory Management" /v "IoPageLockLimit" /t REG_DWORD /d "2147483648" /f
reg add "HKLM\SYSTEM\CurrentControlSet\Control\Session Manager" /v "HeapDeCommitFreeBlockThreshold" /t REG_DWORD /d "262144" /f
reg add "HKLM\SYSTEM\CurrentControlSet\Control\FileSystem" /v "DontVerifyRandomDrivers" /t REG_DWORD /d "1" /f
reg add "HKLM\SYSTEM\CurrentControlSet\Control\FileSystem" /v "LongPathsEnabled" /t REG_DWORD /d "0" /f
reg add "HKLM\SYSTEM\CurrentControlSet\Control\Session Manager\kernel" /v "CacheAwareScheduling" /t REG_DWORD /d "16" /f
reg add "HKLM\SYSTEM\CurrentControlSet\Control\DeviceGuard\Scenarios\HypervisorEnforcedCodeIntegrity" /v "Enabled" /t REG_DWORD /d "0" /f
reg add "HKLM\SYSTEM\CurrentControlSet\Control\Session Manager\kernel" /v "DisableExceptionChainValidation" /t REG_DWORD /d 1 /f
reg add "HKLM\SYSTEM\CurrentControlSet\Control\Session Manager\kernel" /v "KernelSEHOPEnabled" /t REG_DWORD /d 0 /f
reg add "HKLM\SYSTEM\CurrentControlSet\Control\Session Manager\Memory Management" /v "EnableCfg" /t REG_DWORD /d 0 /f
reg add "HKLM\SYSTEM\CurrentControlSet\Control\Session Manager\Memory Management" /v "MoveImages" /t REG_DWORD /d 0 /f
reg add "HKLM\SYSTEM\CurrentControlSet\Control\Session Manager" /v "ProtectionMode" /t Reg_DWORD /d "0" /f
reg add "HKLM\SOFTWARE\Policies\Microsoft\FVE" /v "DisableExternalDMAUnderLock" /t Reg_DWORD /d "0" /f
reg add "HKLM\SOFTWARE\Policies\Microsoft\Windows\DeviceGuard" /v "EnableVirtualizationBasedSecurity" /t Reg_DWORD /d "0" /f
reg add "HKLM\SOFTWARE\Policies\Microsoft\Windows\DeviceGuard" /v "HVCIMATRequired" /t Reg_DWORD /d "0" /f
reg add "HKLM\SOFTWARE\Policies\Microsoft\Windows\Explorer" /v "NoDataExecutionPrevention" /t REG_DWORD /d 1 /f
reg add "HKLM\SOFTWARE\Policies\Microsoft\Windows\System" /v "DisableHHDEP" /t REG_DWORD /d 1 /f
