ZOWIE XL2566K Discussion Thread [24.5" 360hz TN]
R1sk
Re: ZOWIE XL2566K Discussion Thread [24.5" 360hz TN]
Post by R1sk » 09 Mar 2024, 13:35
This monitor lacks about Display Scaling
solz
Post by solz » 21 May 2024, 12:46
Does this monitor has increased input lag if you run it at 240Hz? since some games i play i cant reach 360Hz
Post by Chief Blur Buster » 21 May 2024, 21:36
solz wrote:
21 May 2024, 12:46
To avoid confusing framerate and refreshrate
360 fps 360 Hz = Should be fine
240 fps 360 Hz = Should be fine
240 fps 240 Hz = This is where a possible minor lag problem occurs on certain models that don't stream lower-Hz pixels to the screen in real time (e.g. monitors buffer refresh cycles before scanning out). In other words, monitor may add lag that is about the refreshtime difference of 240 Hz and 360 Hz
The refreshtime difference of 1/240sec and 1/360sec is less than 2 milliseconds, so usually nonissue even if you confuse framerate and refreshrate. The problem is bigger for retro users switching 360Hz down to 60Hz, creating latency penalty that is bigger (1/60sec - 1/360sec = potentially about 14 milliseconds monitor-buffering lag that makes it at least 14ms laggier than a 60Hz CRT tube, even before scanout lag.)
Generally for PC esports you leave monitor at max Hz even with lower frame rates. 100fps on a newly purchased 360Hz monitor can be lower lag than 100fps on a newly purchased 144Hz monitor. That's because of the super fast scanout velocity (The 100fps frame is 1/360sec delivered over the cable from first to last pixel).
wlundstrom
Post by wlundstrom » 03 Jun 2024, 13:07
I just noticed theres a thread dedicated to this monitor, great!
I just compared the clarity with dyac on my monitor to this guy
My XL2566K
Settings are matched and I got 1440 pixels selected but it looks way worse on my unit. I know the tracking isn't great but it closely resembles what my eyes perceive anyway. Is there anybody with a XL2566K who could chime in and let me know what their unit looks like at 1440 pixels?
ASUS 24" VG248QE | ASUS 25" PG259QN
Zwoo
Post by Zwoo » 04 Sep 2024, 10:47
I am getting 240fps in the game should I use 360hz or 240hz. Dyac on or not, how should it be the most suitable with minimum lag. Is there anyone using it like this or should I downgrade to xl2546k? Because on their own site it says both can be used at 240hz, there is no difference between them. Some people claim that 2566k is still advantageous at 240hz.
Post by RealNC » 04 Sep 2024, 11:20
Zwoo wrote:
04 Sep 2024, 10:47
With VRR, use highest Hz. Without VRR, match FPS and Hz.
Zwoo
Post by Zwoo » 04 Sep 2024, 11:53
RealNC wrote:
04 Sep 2024, 11:20
Zwoo wrote:
04 Sep 2024, 10:47
Which one should I do when I play competitively. I'm talking about games like Cs 2 (fps). Should I match fps 240 and hz 240 for competitive?
Post by RealNC » 04 Sep 2024, 12:21
Zwoo wrote:
04 Sep 2024, 11:53
Highest hz for lowest input lag.
kyube
Post by kyube » 10 Sep 2024, 12:56
wlundstrom wrote:
03 Jun 2024, 13:07
--boop--
My XL2566K
--boop--
(disclaimer for others, as you've noticed this yourself: the ufo he recorded cannot be used for comparative measures, it's invalid - refer to chief's guide on how pursuit shot is supposed to look like)
Techless tests at 1440pps (@5:13 if it doesn't embed)
Try making a CRU resolution in the extension block with the DisplayID 2.0 timing with the profile set to Exact Reduced, you might have a unit that frameskips (common)
Or perhaps you've not tuned your unit with the Blurbusters utility.
Post by Slender » 10 Sep 2024, 16:21
someone have same 60hz feel like me?
