What causes a 500Hz mouse to sometimes report at 250Hz or 125 Hz?
Re: What causes a 500Hz mouse to sometimes report at 250Hz or 125 Hz?
i think i have an issue thats come close to the expierience of this Thread, i got this on almost every computer in our house even on a laptop not without connection to power supply ... and when i use high dpi its it seem like its interupting for a very short period especially when i start pushing the mouse or when i have move the mouse in oposite direction or when doin circles or edges so that i cant keep on tracking while gaming... ive made a litte video of my desktop using 1000hz and 2500dpi to make it more visible ... i wanted to post a video link but this side doesnt allow it !!!
Come on brother, I'm following your posts. So far I've ruled out all other possibilities. Everything seems to point to the device manager mouse HID and power supply electrical problems.TooManyPixels wrote: ↑24 Sep 2023, 18:00What causes a 500Hz mouse to sometimes report at 250Hz or 125 Hz?
This particular kind of mouse "lag" is the same one I've been dealing with for the past 4 years.
I don't want to call it "lag" because, strictly-speaking, this isn't a latency issue, but it seems to be a variable sensitivity and/or variable movement report-time. This happens with a variety of mice too, and on a variety of computers (all affected machines have Intel CPUs, I have an unaffected machine with an AMD processor; all machines are running Windows 10 22H2).
I know that moving the mouse very slowly (e.g. 1 mouse-unit per second) will result in MouseTester reporting very slow frequencies - but I get this 250Hz and 125Hz (and oddly, ~167Hz too) when I move my mouse at a reasonable natural speed which should always be reported at 500Hz.
I am aware of XHCI moderation, but the minimum moderation interval is 250ns - but 250Hz is 4ms (quite a few orders of magnitude higher!) - but also because I purchased a StarTech USB 2.0 PCI-Express card (USB 2.0 is EHCI, not XHCI) and I can reproduce the issue when my mouse is plugged into either the USB 2.0 card or my motherboard's USB 3.0 ports.
I cannot reliably reproduce this on-demand, but it tends to happen throughout the day, then be fine for a few days, then reappear again.
Obligatory list of things to mention:
- Issue started affecting me around October 2019
- It happens regardless of the mouse model I'm using (Razer Basilisk V2, Logitech G400, Logitech MX518, some random no-name mice, and interestingly, also it feels like the PS/2 touchpad in my laptop is affected too)
- Affected computers of mine:
- Intel NUC 11 (with Intel i7-1165G7) built in 2021
- ASUS Z490-E (with Intel i7-10700K) built in 2020
- ASUS X99 (with Intel i7-6850K) built in 2016
- Dell XPS 9560 (with Intel i7-7700HQ) built in 2017
- Unaffected computers of mine:
- ASUS X570-E (with AMD Ryzen 7 2700X)
- Issue is reproducible in both USB 2.0 ports in a USB 2.0-only card (this card from StarTech) and in USB 3.0 and USB 3.1 ports on all affected machines.
- Issue happens with Intel CPU-integrated graphics, and with NVIDIA GeForce, AMD Radeon, and AMD Radeon Pro GPUs.
- It definitely is not EMI or anything like that (because it also happens on my XPS laptop when I'm in the outdoors, or anywhere)
- LatencyMon Pro 7.31 shows nothing unusual even when I can reproduce the issue
- The older dpclat.exe seems to think there's a 1000us latency, but given the age of the program ("DPC Latency Checker V1.4.0" is from 2015) it predates Windows 10 entirely and I understand MS made changes to how applications can access system timers since then.
- I have fiddled with EFI and Windows boot settings (e.g. HPET, UsePlatformTick, DisableDynamicTick, and the rest, to no effect, and I'm familiar with this article too).
- Disabling/removing all networking hardware made no difference (so the first person to say "bufferbloat" unironically gets a stabbing).
I found that every time I disable the branch HID\VID_046D&PID_C539&REV_3906&MI_01&Col04 under the mouse item, the input delay will get better. This is the only constant among all the short-term placebos. It can be stably reproduced. So I think your research is very valuable. You can discuss more with the moderator.
Sandy wrote: ↑08 Jun 2024, 12:30Come on brother, I'm following your posts. So far I've ruled out all other possibilities. Everything seems to point to the device manager mouse HID and power supply electrical problems.TooManyPixels wrote: ↑24 Sep 2023, 18:00What causes a 500Hz mouse to sometimes report at 250Hz or 125 Hz?
is mine ok ?
- yhid.GIF (9.95 KiB) Viewed 3605 times
It will recover repeatedly. Only one of the HID items is associated with the mouse, but even so it will recover.JimCarry wrote: ↑08 Jun 2024, 14:38Sandy wrote: ↑08 Jun 2024, 12:30Come on brother, I'm following your posts. So far I've ruled out all other possibilities. Everything seems to point to the device manager mouse HID and power supply electrical problems.TooManyPixels wrote: ↑24 Sep 2023, 18:00What causes a 500Hz mouse to sometimes report at 250Hz or 125 Hz?
is mine ok ?
[/quote]
Is there a way not to recover?
[/quote]
I'm going to buy a double conversion UPS. This is my last hope.
[/quote]
Ok thanks,can you do update when you buy it ?
At this point, I think the problem is in mouclass.sys
