Very healthy BIOS optimization
Riggedinho
Post by Riggedinho » 24 Jun 2024, 05:21
I'm sharing the healthiest Bios optimization I found, which is recent and what's more comes from an article on the Linkedin site (lol)
How can you optimize your BIOS settings for maximum gaming performance?
When it comes to gaming, every millisecond counts, and optimizing your BIOS can give you a competitive advantage. BIOS, which stands for Basic Input/Output System, controls communication between your operating system and the computer hardware. Adjusting the right settings can improve performance and stability while gaming. Although it may seem intimidating, with a little guidance you can fine-tune your system's BIOS for optimal gaming performance.
1
Update BIOS
2
Enable XMP
3
Configure the GPU
4
Turn off unused devices
5
Adjust power settings
6
Fine-tuning fan control
1 Update BIOS (Only if you are having problems or your current version is quite old)
Before you start optimizing, make sure your BIOS is up to date. Manufacturers often release updates that improve stability, compatibility, and performance. Updating your BIOS can resolve existing issues and provide new features or settings that may improve gaming performance. It's a simple process: just download the latest firmware from the support site of your motherboard and follow the instructions provided for the update process.
2 Enable XMP
To get the most out of your memory, enable XMP (Extreme Memory Profile). This setting tells your system to use higher memory speeds and tighter timings, which can significantly impact gaming performance by reducing load times and improving frame rates. XMP is essentially a pre-configured profile that makes it easy to overclock your RAM. Simply locate the XMP option in your BIOS and enable it for an instant performance boost.
3 Configure the GPU
Optimizing Your Graphics Processing Unit (GPU) Performance is crucial for gaming. In BIOS, you can set your GPU as the primary display adapter, ensuring that games use its full power. Additionally, if your system supports it, enable PCIe (Peripheral Component Interconnect Express) Gen 3 or Gen 4 for faster data transfer rates between your motherboard and GPU. This can result in smoother graphics and better overall gaming performance.
4 Turn off unused devices
Your system resources should be focused on gaming, so turn off any onboard hardware you're not using. By disabling unused ports or onboard peripherals such as audio chips or network controllers in the BIOS, you free up resources that can then be allocated to improve gaming performance. This can also help reduce potential conflicts between different hardware components, which leads to a more stable gaming experience.
5 Adjust power settings
BIOS power settings can also influence gaming performance. Enable “High Performance” mode to allow your CPU and other components to run at their maximum speed without throttling. Be aware that this can increase energy consumption and heat production, so make sure your cooling system is adequate. Additionally, disabling power-saving features like C1E (Enhanced Shutdown State) can prevent the CPU from slowing down in low-demand situations, which is beneficial for games that require consistent performance.
6 Fine adjustment of fan control (This section is not useful if cooling works very well in standard mode)
Effective cooling is essential to maintaining performance, especially when you're pushing your hardware. Many BIOS setups offer customizable fan control settings that allow you to create a balance between noise level and cooling efficiency. By adjusting fan curves or setting temperature goals, you ensure your system stays cool under load without sounding like a jet engine, preserving both performance and immersion in your gaming sessions.
Riggedinho
Re: Very healthy BIOS optimization
Post by Riggedinho » 24 Jun 2024, 05:51
For my part, I had not dared to touch my BIOS since I fixed my input delay problem because of Faceit's anti-cheat but this very simple, credible and current optimization (article written May 2, 2024) inspired me.
I haven't updated my BIOS because I have the penultimate version and I have no problems.
I have not activated XMP because on my Asrock motherboard my RAM (32 GB Lexar 2x16 GB) is not compatible.
I set my GPU as primary display adapter and chose generation 4 for PCIe
For things that I don't use so are useless that I deactivated there are :
- On board WAN device
- VT-d
- Intel Virtualization
For the power settings I changed :
- Voltage mode: Stable Mode
- CPU Core/Cache voltage: Fixed Mode (Needs good cooling)
- CPU Core/Cache Load-Line Calibration: Level 1 (Needs good cooling)
- Boot Performance Mode: Turbo Performance
- For C-State I only deactivated C1E (the one specified in the advice in the article) and did not touch the others so they are activated.
I left my ventirad in standard mode because it works very well that way.
You will notice that I carefully followed the advice in the Linkedin article and did not change anything else.
Tomso
Post by Tomso » 13 Jan 2026, 17:08
Hey! :shock: How did you fixed input delay problem on Faceit's anti-cheat?
Espionage724
Post by Espionage724 » 15 Jan 2026, 22:04
Riggedinho wrote:
24 Jun 2024, 05:21
1
Update BIOS
Funny :lol: Newer BIOS includes newer CPU (and USB/etc) mitigations that don't usually improve performance.
I use a 2018 BIOS on a 2019 MFG laptop for speed 8-) (even remove OS microcode)
Hyote
Post by Hyote » 16 Jan 2026, 14:01
Espionage724 wrote:
15 Jan 2026, 22:04
Riggedinho wrote:
24 Jun 2024, 05:21
1
Update BIOS
Sorry, I just can't keep myself from commenting about everything lately. That doesn't remove the microcode, only disables it on an OS level. It's best to remove from the BIOS file itself with mmtool. I also agree with older BIOS versions usually being better in every aspect.
Post by Slender » 16 Jan 2026, 14:02
Espionage724 wrote:
15 Jan 2026, 22:04
Riggedinho wrote:
24 Jun 2024, 05:21
1
Update BIOS
how to decrease me on intel z390?
Hyote
Post by Hyote » 16 Jan 2026, 16:40
Slender wrote:
16 Jan 2026, 14:02
Espionage724 wrote:
15 Jan 2026, 22:04
Riggedinho wrote:
24 Jun 2024, 05:21
1
Update BIOS
Can't you just disable it through SCEWIN or remove it with https://github.com/corna/me_cleaner
