BenQ XL2411z darker at top part
zefs
Post by zefs » 10 Oct 2014, 05:15
Hello, I recently got a BenQ XL2411z, upgraded to V2 firmware and have set it up as I like. I've noticed that it's darker on the top of the screen then goes lighter on the bottom, it's like having a gradient so I just wanted to ask if other owners have observed the same thing?
Falkentyne
Re: BenQ XL2411z darker at top part
Post by Falkentyne » 10 Oct 2014, 07:44
What happens if you move your head up towards the top of the screen?
Because you sound like you're describing gamma/color shift ,which is going to show worse on a 27" than a 24".
zefs
Post by zefs » 10 Oct 2014, 08:58
Falkentyne wrote:What happens if you move your head up towards the top of the screen?
It becomes lighter, but if I set the monitor height to fix that "issue" then bottom part becomes even lighter/washed.
I suppose it's the viewing angles and the TN panel but thought of asking if other owners have the same or it's different from model to model. I guess there is no way to fix that?
