Seeking Advice on Monitor Purchase - Apple Studio Display Issues and Potential OLED Solution
There are over 100 ergonomic issues from displays, far more than just flicker and blue light. This forum covers the giant variety of display ergonomics issues.
blurdeluxe
Post by blurdeluxe » 19 Aug 2024, 20:30
Hi everyone,
First off, I want to express my gratitude to all the contributors on this forum. Your insights have been incredibly helpful to so many, including myself, as I navigate the complex world of display technology.
I'm currently in the market for a new monitor primarily for productivity and coding. I've recently tried the Apple Studio Display, but unfortunately, it caused me significant discomfort, including headaches. Interestingly, I don't experience these issues with my MacBook Pro, which has a Liquid Retina XDR display, unless I'm extremely tired. My iPhone 13 Pro and OLED TV also seem to work fine for me, so this experience with the Studio Display was quite unexpected.
I had a brief experience using the Samsung F32TU874VN in the office, and while it wasn't a rigorous test, I didn't encounter any problems during those few hours. The panel looked 'flat' and slightly dull but not bright which felt like welcome relief.
I'm now considering the Philips 27E1N8900, a 26.9" 4K HDR OLED monitor, which supposedly offers clearer text because of the RGB subpixel layout (and deeper blacks of OLEDs emitting less light to my eyes). One of the challenges I faced with the Studio Display was that it always seemed excessively bright, even when using dark themes in my code editor. I'm thinking that a monitor with high resolution and deep blacks might be a better fit, but I'm not entirely sure what the root cause of my discomfort is.
Before I go through the hassle of purchasing and potentially returning multiple monitors, I was hoping to get some pointers or advice from those of you who might have had similar experiences. Is there something specific I should be looking for in a monitor to avoid this issue? Any suggestions would be greatly appreciated!
Thanks again for all your help!
kyube
Re: Seeking Advice on Monitor Purchase - Apple Studio Display Issues and Potential OLED Solution
Post by kyube » 20 Aug 2024, 09:58
blurdeluxe wrote: ↑
19 Aug 2024, 20:30
Hi everyone,
RGB OLED is definitely a good consideration to try.
This specific part might be the issue here. Do you use your displays in pitch black rooms, lacking ambient lighting?
You can verify the brightness of a display by hand using apps, such as shown here:
I'm not sure if this iOS version is good, give it a shot: https://apps.apple.com/us/app/lux-light ... 1292598866
https://www.rtings.com/monitor/reviews/ ... io-display
If this review is correct and you're using your monitor at max brightness, 600nits is VERY bright and should be avoided for indoors use imo.
blurdeluxe
Post by blurdeluxe » 20 Aug 2024, 14:25
Thanks @kyube - I use my monitor in a room with plenty of daylight and would turn the Apple Studio Display right down to its lowest brightness setting but there was still something about looking at that screen that made my head swim.
I feel like the ideal display would be a much larger version of my Apple Macbook Pro 14" liquid retina display XDR but haven't seen anything that fits the bill. I think its basically a very hi-res mini-LED display with some other propriertary Apple tech.
My sense is that it has something to do with the fact that the Apple Studio Display is an IPS monitor with no dimming zones just one big uniform backlight, that even when trying to represent blacks is still blasting the eyes with a lot of light. My MacBook Pro has about 500 dimming zones I think. Which took me down the path of thinking that OLED might be good because each LED provides its own light without one big backlight (I believe that's how it works).
Then I got a surprise after using the Samsung F32TU874VN for a bit, which I think has one big backlight and no dimming zones at all but from what I understand VN panels are really good at blacks so they must block a lot of light.
