Is anyone not experiencing stutter and increased input lag on Adrenaline 24.x.x drivers?
Sintek
Post by Sintek » 20 Aug 2024, 15:12
The 24-series GPU drivers from AMD are at 24.7.1 now and, like all previous 24.x releases, the system-wide stutters and increased input lag relative to the 23.12.1 drivers are still present for me. I've tried on both Windows 10 and 11, existing and fresh installs.
The notes for the first few releases made mention of the stuttering, but even after they stopped listing it the issue remained, at least for me.
Specs
48" LG C2 4k@100hz w/ FreeSync
14700K
MSI z790 Tomahawk
48GB DDR5 C40 8000 @ 7000
XFX 7900XTX
Hyote
Re: Is anyone not experiencing stutter and increased input lag on Adrenaline 24.x.x drivers?
Post by Hyote » 20 Aug 2024, 22:21
Gonna check and report back. No stutters but maybe better input latency on 23.10.2
Hyote
Post by Hyote » 23 Aug 2024, 00:55
No stutters with the new drivers but 23.10.2 is definitely a lot better in every way.
JimCarry
Post by JimCarry » 26 Aug 2024, 09:47
So today i check if there is new drivers, and it turns out i have the latest version but in the amd site they revert the newest driver to their last one,and now i have the new one can someone explains please ?
JimCarry
Post by JimCarry » 10 Sep 2024, 11:18
I am still with the newest drivers that is not even released.never buy amd vc!
dont buy amd vc.GIF (67.48 KiB) Viewed 3862 times
themagic
Post by themagic » 10 Sep 2024, 12:12
JimCarry wrote:
10 Sep 2024, 11:18
What Rank are you with this GPU in the games like Valorant or CS2 ?
I have same GPU and get like 300fps+ in valorant with middle settings...
JimCarry
Post by JimCarry » 10 Sep 2024, 12:19
themagic wrote:
10 Sep 2024, 12:12
JimCarry wrote:
10 Sep 2024, 11:18
In gaylorant and cs2 for high fps you must have good cpu, its not about gpu,i have 100fps but my cpu is i5 6600,i am level 7 in face it.
themagic
Post by themagic » 10 Sep 2024, 12:23
JimCarry wrote:
10 Sep 2024, 12:19
themagic wrote:
10 Sep 2024, 12:12
JimCarry wrote:
10 Sep 2024, 11:18
is i5 9400F enough for an rx580 ?
JimCarry
Post by JimCarry » 10 Sep 2024, 12:28
themagic wrote:
10 Sep 2024, 12:23
JimCarry wrote:
10 Sep 2024, 12:19
themagic wrote:
10 Sep 2024, 12:12
JimCarry wrote:
10 Sep 2024, 11:18
maybe, but in my case my motherboard only have "Above 4G Decoding" and does not have Resizable BAR,and even tho my vc is 8gb i can only use 256mb.in the screen the app says that "Resizable BAR" is disabled but on my motherboard it does not exist,i update my bios to the last one and it still the same.
old mb.GIF (61.72 KiB) Viewed 3786 times
themagic
Post by themagic » 25 Sep 2024, 00:41
JimCarry wrote:
10 Sep 2024, 12:28
themagic wrote:
10 Sep 2024, 12:23
JimCarry wrote:
10 Sep 2024, 12:19
themagic wrote:
10 Sep 2024, 12:12
I manage to enable it through regedit and now it says that it is enabled and uses full amount of memory.
You tried to find Resizeable Bar Option through Scewin and enable it that way ? maybe gonna works for you too then.
And you need disable CSM and go UEFI after..
here the regedit tweak:
https://www.reddit.com/r/AMDHelp/commen ... eable_bar/
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\Class{4d36e968-e325-11ce-bfc1-08002be10318}\0000] "KMD_EnableReBarForLegacyASIC"=dword:00000001 "KMD_RebarControlMode"=dword:00000001 "KMD_RebarControlSupport"=dword:00000001
Have no Idea if this thing rly working and does something because i noticed zero differences but read that in some games it rly gives up to 20% performance boost.
The thing which i dont understand why it still says: hardware support [NO] and driver support [Unsupported GPU] in GPUz.
