New input lag champion?
Q83Ia7ta
Post by Q83Ia7ta » 17 Oct 2014, 13:36
ASUS ROG SWIFT PG278Q
When ASUS PG278Q we measure 4.8 milliseconds at 60Hz and 144Hz for a very short signal delay. Half the mean image change time is 1.4 millisecond also very short, making the total outstanding 6.2 milliseconds.
http://webcache.googleusercontent.com/s ... teil9.html
LG 24GM77
When ASUS PG278Q we measure at 1.4 milliseconds at 60Hz and 144Hz for a very short signal delay. Half the mean image change time is 2 millisecond also very short, making a total of sensational 3.4 milliseconds.
http://prad.de/new/monitore/test/2014/t ... teil8.html
Due some test BenQ XL2720Z performs
like http://pclab.pl/art58968-8.html
flood
Re: New input lag champion?
Post by flood » 17 Oct 2014, 17:31
well first of all crt's are the existing champion
check the prad.de measurements for the vg248qe. there's nothing really new here.
4.8ms for the rog swift is pretty high compared to the 24inch 144hz displays, but still low enough to not really affect performance
Q83Ia7ta
Post by Q83Ia7ta » 17 Oct 2014, 19:26
flood wrote:well first of all crt's are the existing champion
I mean champion in lightweight class between consumer LCD monitors. They have changed methodology(test) and vg248qe result can't be compared.
flood
Post by flood » 18 Oct 2014, 21:10
Q83Ia7ta wrote:They have changed methodology(test) and vg248qe result can't be compared.
that's really vague.. please explain
Q83Ia7ta
Post by Q83Ia7ta » 19 Oct 2014, 09:45
Just look at the dates.
Asus VG248QE
Review publication date: 10.06.2013
Latency test at 144Hz: Yes
Philips 242G5DJEB
27.01.2014
Yes
BenQ BenQ XL2420T 144Hz revision
19.05.2014
Latency test at 144Hz: No. "Bei diesem Test konnten wir die Latenzzeit bei 144Hz leider nicht ermitteln." (translation: In this test, we could not determine the latency at 144Hz unfortunately.)
Iiyama ProLite GB2773HS-GB1
16.06.2014
BenQ XL2720Z.
11.08.2014
Acer GN246HLBbid
22.09.2014
Yes.
LG 24GM77-B
10.10.2014
Yes.
Asus PG278Q
14.10.2014
Yes.
Black Octagon
Post by Black Octagon » 20 Oct 2014, 01:23
Pretty sure PRAD would have written an article to announce and explain any change to their methodology...they did that when they started using an oscilloscope
flood
Post by flood » 20 Oct 2014, 06:39
Q83Ia7ta wrote: Just look at the dates.
not sure if serious.........................................
