Magnet? ( Not placebo)
- RealNC
Re: Magnet? ( Not placebo)
Moved to the correct forum section.
ablemor
Actually, I think if you place it near the power supply, it should be fine. Yesterday, I placed it on the back of my computer, but honestly, the effect was the same. The magnet is about this size, and I'll buy a few more and put 2-3 more on it. I don't think it will cause any problems. I don't use HDDs, so the magnet shouldn't cause any damage, but if anyone is knowledgeable about this, please let me know. Also, how could I solve this without using magnets? Is the power supply faulty? It's an ASUS ROG 750W Gold, which I believe is a very good power supply.
ablemor
How interesting that such a small magnet instantly stopped the floaty mouse movement, and I could play exactly how I wanted to. I really enjoyed the game.
- themagic
There so many Crazy experience with that all stuff...some People just moving cables inside and get posetive short effect.
Then there some who tried using different screws for motherboard instead of black ones and get posetive effect.
I myself had crazy experience when touching CMOS jumper with this thing "CH341A 24 25 Series EEPROM Flash BIOS USB Programmer Module + SOIC8 Test C..ti"
The purpose of this thing is to flash/programm chips and things but i just put it in USB and make contact with CMOS reset jumper and after PC went off but the first Match after in Valorant was just amazing and advantage pur for me.
Or i make contact with screws or anything where the clipper would fit (like on gpu backside and screws) and had same crazy effect but only for 1 match and after this magicfix.exe stopped work when i tried to repeat those steps and after tried to figure out why and how in hell and what that all bullshit means...
but without success...im to stupid.
Its all very Mental and Crazy but still no one find the correct explanation for this and the full fix about all this or atleast how to make it stable for longer and not only for 2-3 somehow Matches...So that it works always like at first time when apply those magnets or ferrites or tinfoil and more of similar experiments...
Almost same like the Russlan guys who find out that Coaxial cables or Irons gives them posetive and like fixed effect and it goes same away too after some Minutes of FUN..
But i 100% believe you by saying that this all is "not just placebo".
- themagic
btw...which Aorus is that ? Rx580 ?
ablemor
Z790 AORUS ELITE AX
GTX 1080 TI
GTX 1080 TI
- themagic
nice gpu and looks nice. i have similar aorus but in amd rx580 gigabyte style.
at what rank you stuck in valorant ? if not secret...im just interested. you can PM me about it if you dont want tell here in public. or better send me tracker if possible...would be nice. i have a theory about my issue and many others..which dont has to do at all with gpu and pc setups but something else and about people like you and similar. or if you dont play Valorant then send some CS2 faceit or any stats from you and some gameplay footage would be rly nice where you feel that you have disadvantage and all the bad things happen from bad aim mouse and movements and more...
Unreazz
This post came up like maybe 1 - 2 years ago ? its probably even the same guy, because i remember it and went buying a magnet to and tested it. nothing changed and i don't understand why this even coming up again
- themagic
For sure it dont change anything but it gives this guy for some moment a feeling and experience of good fixed gameplay match where he could feel good aim and nice hitreg and advantage in some matches and that is true and real...thats all what is about. and its not some placebo...cause many exprience the same shit and describe the same shit over and over.
but no one able to explain why that happens and how exactly this works and why after some matches or hours it becomes shit again...that the most funny thing about this all.
call me crazy but im not the crazy one...
Mugabi
This affects bioenergy field that comes in contact with surface of computer. Try to play next to narcissist next time and inthink your lag will go due to bad energy
