You can clearly see the XG2431 LCD has BETTER G2G and objection motion blur at 60 HZ / 60 FPS than the OLED has at 240 HZ / 240 FPS
Now imagine what 120 HZ is capable of?
^ 240 HZ OLED
60HZ LCD XG2431 strobed
That's not how things work. Impulse-driven MPRT is NOT exactly the same as framerate-driven MPRT! True 1000Hz 1000fps 1ms MPRT looks and feels much more life-like as opposed to 120Hz 120fps 1ms MPRT.Supermodel_Evelynn wrote: OOh I almost forgot this is 120 HZ Strobing on the XG2431 and we know full well this is better than a 1000 HZ OLED
GtG and MPRT are separate metrics. Essentialy end result is composit of the two. LC will probably never be as fast as LED.Supermodel_Evelynn post wrote: You can clearly see the XG2431 LCD has BETTER G2G and objection motion blur at 60 HZ / 60 FPS than the OLED has at 240 HZ / 240 FPS
