Then how its possible that my aim is much much better with 5 times lower fps offline vs online ?
Device firmware re-flash gave positive effect
SKILLEN
Re: Device firmware re-flash gave positive effect
- Slender
you mean your offline fps vs online lower in 5 times then online ?
ok, just get 60fps offline and 300fps online.
If you have that issue, more power pc consumption = more lag.
I don't know the reason for this, but I assume that the more computing power that needs to be processed, the harder the error corrector works.
this directly explains why 60fps is better then 300fps.
SKILLEN
Slender wrote: β06 Oct 2024, 13:28you mean your offline fps vs online lower in 5 times then online ?
It doesn't matter how many fps i have. I just told you how ridiculous the lag is. With 200-300-500 fps online i'm aiming like when i was 7 years old. Of course offline with 300fps is better than 60fps offline,but 60fps offline is infinity better than whatever fps max i set online.
it has nothing with processed power. Same problem with 20 years old cs 1.6
MegaMelmek
Slender explained to you that when you play online the PC eat way more power then offline. Just do simple test try download something and look at your CPU usageSKILLEN wrote: β06 Oct 2024, 13:40Slender wrote: β06 Oct 2024, 13:28you mean your offline fps vs online lower in 5 times then online ?
SKILLEN
MegaMelmek wrote: β06 Oct 2024, 13:54Slender explained to you that when you play online the PC eat way more power then offline. Just do simple test try download something and look at your CPU usageSKILLEN wrote: β06 Oct 2024, 13:40Slender wrote: β06 Oct 2024, 13:28you mean your offline fps vs online lower in 5 times then online ?
Im not sure he said that,because offline with bots is more taxing for the pc and if i uncap the fps is lower than online,but still there is no problem . How is downloading similar to online cs . Cs uses like 1mbit . And if you mean downloading and playing offline,yes still no problem.
- Slender
first of all, what are your problems? Poor hit registration? 360hz feel like 60hz? unsmooth? Does everyone see you first? What is your connection? optical / wire ? do you try wifi?SKILLEN wrote: β06 Oct 2024, 14:01MegaMelmek wrote: β06 Oct 2024, 13:54Slender explained to you that when you play online the PC eat way more power then offline. Just do simple test try download something and look at your CPU usageSKILLEN wrote: β06 Oct 2024, 13:40Slender wrote: β06 Oct 2024, 13:28
SKILLEN
Slender wrote: β06 Oct 2024, 14:22first of all, what are your problems? Poor hit registration? 360hz feel like 60hz? unsmooth? Does everyone see you first? What is your connection? optical / wire ? do you try wifi?SKILLEN wrote: β06 Oct 2024, 14:01MegaMelmek wrote: β06 Oct 2024, 13:54Slender explained to you that when you play online the PC eat way more power then offline. Just do simple test try download something and look at your CPU usageSKILLEN wrote: β06 Oct 2024, 13:40
When i join server online i can tell immediately that my mouse is not moving the same as offline. When i see enemy something is happening it feels like vertical sync is on i cant put my crosshair in enemy i even struggle to kill from behind,often i miss kills that no human who have 500h should miss. When there are more enemies in front of me its getting worse.But also its very bad if there is no enemy in my sight. In freezetime when we buy weapons,its better.
Like i said fps doesnt matter. This is happening with 60 ,100 ,200 ,300 ,uncapped. My statistics in faceit are 35-40% worse than before,obviously this is not possible.
Playing with cable ,cat5 ,cat6,cat8,routers,wi fi cards,3g ,4g,5g, many isps,fiber,cable
- Slender
day and night difference?SKILLEN wrote: β06 Oct 2024, 14:57Slender wrote: β06 Oct 2024, 14:22first of all, what are your problems? Poor hit registration? 360hz feel like 60hz? unsmooth? Does everyone see you first? What is your connection? optical / wire ? do you try wifi?SKILLEN wrote: β06 Oct 2024, 14:01MegaMelmek wrote: β06 Oct 2024, 13:54
SKILLEN
[/quote]
No difference that i can tell ; \
I should tell you that i also tried starlink and i was sure that this will fix the problem,because there is nothing else left to try,but it didnt.
[/quote]
- Slender
