try to connect monitor to unground socetInputlucker wrote: ↑04 Sep 2024, 03:54After i bought an LG gr95qeb, which is 240 hz oled panel, my mousetester graph looks like that. It was the same with 9700kf, now with 7800x3d. But with 14700kf there was no those arrows every 1500ms, line was straight between 998-1002. This happens only with adaptive sync turned on. On 144 hz refresh rate with adaptive sync turned on issue seems less visible. I tried changing dp cables, hdmi 2.1, tweaking monitor settings, different nvidia drivers. C states disable, only c0 and c1. Also cpu usb port in mousetester looks worse than chipset one. Please share your toughts, what might be causing this behavior.
Weird mousetester result
- Slender
Re: Weird mousetester result
- St1cky
Sorry for the late response, i got a new Gpu, 4070 upgraded from 1070. Issue is still persistence.Inputlucker wrote: ↑13 Nov 2024, 05:42Hi there and sorry for my English.St1cky wrote: ↑06 Nov 2024, 21:36Looks like its not fixed on newest driver for me.Inputlucker wrote: ↑08 Sep 2024, 08:10Yes, you were right, previously i used 537.58 driver and earlier, which were the cause of those arrow lines on my graph. Drivers past 556.12 solved that. But on Intel 14700kf even 537.58 behaves normal.
566.03-desktop-win10-win11-64bit-international-dch-whql
9700k
1070
My result now broken too no matter which driver i use, so the culprit maybe in Windows itself, or in both Windows and nvidia drivers. But, i think it didnt matter too much having straight line, i have laptop with 11400f and 3050ti which had to work perfectly when i was at my work (there was fiber 100 mb connection, i use wifi, and outlets have no grounding), mousetester result btw was even worse than yours. And at my house i cant play the same on this laptop and even on my 2k $ p with oled 240 hz panel, so i conclude that the issue in electricity line or my connection 800mb/s fiber. In night time around 3 a. m. after fresh Windows reinstalled my Pubg gameplay is perfect, cs 2 deathmath - almost every hit registeres even if i should miss, player model is very light, actions perform very responsive. I tested my pc with monitor in my friends houses - in first house there was instant improvement, in second house - almost the same situation as in my house.
Thinks i know for sure about this anomaly is:
- Not happening on 1803 Build Windows 10
Its happening maybe since QPC/QPF was changed in 1809+?
- Issue is persistence at Windows 11
- not related to USB Controller ( Switched from Intel to Asmedia, same issue )
- Not related to BIOS, Public Settings ( Power Settings can affect it yes or its just hidding in Mousetester, but still there )
- Tested mouse on other PC, Chipset 200 Series and 7700k Intel, issue is there not happening
( Same house other room, but room is connected to other Phase. )
- On debloated OS with Ntlite, Issue is even more clearly!
- Tested my PC at a other Location, same Issue
- Replaced Mainboard/CPU/PSU/RAM/MONITOR same issue
I have no clue whats causing it.
Whats even wierder is, it looks like its happening in a interval.
I never figured out, what is causing this!
And i tried a lot in those years. It could be very well Electrician ( Power Noise, etc ) issue.
Did you tested mousetester at the other places?
Keep in mind my arrows are looking in the other direction
Here is my Discord for faster response:
st1cky7799
- St1cky
Its not related to monitor. :SSlender wrote: ↑13 Nov 2024, 15:21try to connect monitor to unground socetInputlucker wrote: ↑04 Sep 2024, 03:54After i bought an LG gr95qeb, which is 240 hz oled panel, my mousetester graph looks like that. It was the same with 9700kf, now with 7800x3d. But with 14700kf there was no those arrows every 1500ms, line was straight between 998-1002. This happens only with adaptive sync turned on. On 144 hz refresh rate with adaptive sync turned on issue seems less visible. I tried changing dp cables, hdmi 2.1, tweaking monitor settings, different nvidia drivers. C states disable, only c0 and c1. Also cpu usb port in mousetester looks worse than chipset one. Please share your toughts, what might be causing this behavior.
You can just unplug the Monitor and do the Mousetester test, same issue.
I will test without ground maybe and other Phase in house.
Since room Phases are either L1,L2,L3.
What i need to add is, when House was completly Powered Down and only PC was running, it was perfect! Sadly i didnt checked Mousetester at that time.
- Slender
i had same problem. you can find my topic with 9700k and 13700k. (i have same with 5800x too)St1cky wrote: ↑04 Dec 2024, 05:24Its not related to monitor. :SSlender wrote: ↑13 Nov 2024, 15:21try to connect monitor to unground socetInputlucker wrote: ↑04 Sep 2024, 03:54After i bought an LG gr95qeb, which is 240 hz oled panel, my mousetester graph looks like that. It was the same with 9700kf, now with 7800x3d. But with 14700kf there was no those arrows every 1500ms, line was straight between 998-1002. This happens only with adaptive sync turned on. On 144 hz refresh rate with adaptive sync turned on issue seems less visible. I tried changing dp cables, hdmi 2.1, tweaking monitor settings, different nvidia drivers. C states disable, only c0 and c1. Also cpu usb port in mousetester looks worse than chipset one. Please share your toughts, what might be causing this behavior.
with 9700k, that issue resolved by moving parts out of case.
5800x i cant resolve it because it be gpu issue (after i disable gpu on am4 i get stable 999.5-1000.5).
with 13700k i dont have that issue, but i cant get perfect line like on 9700k. maybe problem just lowering.
Try CSM mode, try mcs9990.
make sure your pc / monitor connection is true.
phase to phase
neutral to neutral
- St1cky
what parts you moved outside of case?Slender wrote: ↑04 Dec 2024, 05:47i had same problem. you can find my topic with 9700k and 13700k. (i have same with 5800x too)St1cky wrote: ↑04 Dec 2024, 05:24Its not related to monitor. :SSlender wrote: ↑13 Nov 2024, 15:21try to connect monitor to unground socetInputlucker wrote: ↑04 Sep 2024, 03:54After i bought an LG gr95qeb, which is 240 hz oled panel, my mousetester graph looks like that. It was the same with 9700kf, now with 7800x3d. But with 14700kf there was no those arrows every 1500ms, line was straight between 998-1002. This happens only with adaptive sync turned on. On 144 hz refresh rate with adaptive sync turned on issue seems less visible. I tried changing dp cables, hdmi 2.1, tweaking monitor settings, different nvidia drivers. C states disable, only c0 and c1. Also cpu usb port in mousetester looks worse than chipset one. Please share your toughts, what might be causing this behavior.
phase to phase
neutral to neutral
So its elect. issue?
yeah i have 9700k too
nothing to do with bios settings, tested all.same issue
- Slender
I pulled everything out of the case. I placed the motherboard on the box. I also remember that the cable was not connected correctly. on 9700k, I had a problem with the PC freezing when opening faceit ac. It was related to the video card. My PC simply could not turn off and reboot, it simply froze. it was 1080ti, but 3060ti had the same effect on the 9700k z390. CSM mode solved the reboot problem, but that is not fix. Reinstall drivers ddu not fix. Only reinstall windows can fix that issue (sometimes not).St1cky wrote: ↑04 Dec 2024, 06:00what parts you moved outside of case?Slender wrote: ↑04 Dec 2024, 05:47i had same problem. you can find my topic with 9700k and 13700k. (i have same with 5800x too)St1cky wrote: ↑04 Dec 2024, 05:24Its not related to monitor. :S
phase to phase
neutral to neutral
- St1cky
I dont think its because of gpu, when i tested other pc with same gpu i had before. ( 1070 )Slender wrote: ↑04 Dec 2024, 06:06I pulled everything out of the case. I placed the motherboard on the box. I also remember that the cable was not connected correctly. on 9700k, I had a problem with the PC freezing when opening faceit ac. It was related to the video card. My PC simply could not turn off and reboot, it simply froze. it was 1080ti, but 3060ti had the same effect on the 9700k z390. CSM mode solved the reboot problem, but that is not fix. Reinstall drivers ddu not fix. Only reinstall windows can fix that issue (sometimes not).St1cky wrote: ↑04 Dec 2024, 06:00what parts you moved outside of case?Slender wrote: ↑04 Dec 2024, 05:47i had same problem. you can find my topic with 9700k and 13700k. (i have same with 5800x too)St1cky wrote: ↑04 Dec 2024, 05:24
phase to phase
neutral to neutral
just other room, issue is not happening?
and issue is not happening at 1803 build at all?^^
- Slender
i dont know. only difference i see 1803 vs new build's it nic controller is "started" vs "not started" in new builds. ye 1803 latest windows with worked timer.St1cky wrote: ↑04 Dec 2024, 06:36I dont think its because of gpu, when i tested other pc with same gpu i had before. ( 1070 )Slender wrote: ↑04 Dec 2024, 06:06I pulled everything out of the case. I placed the motherboard on the box. I also remember that the cable was not connected correctly. on 9700k, I had a problem with the PC freezing when opening faceit ac. It was related to the video card. My PC simply could not turn off and reboot, it simply froze. it was 1080ti, but 3060ti had the same effect on the 9700k z390. CSM mode solved the reboot problem, but that is not fix. Reinstall drivers ddu not fix. Only reinstall windows can fix that issue (sometimes not).St1cky wrote: ↑04 Dec 2024, 06:00what parts you moved outside of case?Slender wrote: ↑04 Dec 2024, 05:47
phase to phase
neutral to neutral
1070 4070 will be same with that issue.
just try disable GPU and NIC driver.
if you have another installed use software RAPR from github to force delete all drivers exept gpu nic
"just other room, issue is not happening?"
what you mean?
- St1cky
When tested on gf pc in other room, my mouse its not happening there.Slender wrote: ↑04 Dec 2024, 06:45i dont know. only difference i see 1803 vs new build's it nic controller is "started" vs "not started" in new builds. ye 1803 latest windows with worked timer.St1cky wrote: ↑04 Dec 2024, 06:36I dont think its because of gpu, when i tested other pc with same gpu i had before. ( 1070 )Slender wrote: ↑04 Dec 2024, 06:06I pulled everything out of the case. I placed the motherboard on the box. I also remember that the cable was not connected correctly. on 9700k, I had a problem with the PC freezing when opening faceit ac. It was related to the video card. My PC simply could not turn off and reboot, it simply froze. it was 1080ti, but 3060ti had the same effect on the 9700k z390. CSM mode solved the reboot problem, but that is not fix. Reinstall drivers ddu not fix. Only reinstall windows can fix that issue (sometimes not).
what you mean?
Same 1070 7700k cpu.. same as i had in the past and with that hw i had same issue.
I will recheck later again and i test without nvme drive.
- St1cky
1803 after install:
1803 after gpu driver install:
1803 instant measure after boot:
Looks like it will change after a specific time after everything is loaded up.
1803 XHCI Interrupts changed to all cores except 0C and 1C. :
