Best monitor for FPS.
rootsoft
Post by rootsoft » 01 Nov 2014, 13:14
I'm a bit outdated now with the new technology and would like some input.
I have a ASUS VG248QE and would like to know what is the best monitor hands down for FPS gaming.
I still feel a little bit of blur while making fast movements with my current setup.
Thank you in advance!
PS. Let me know if i should be waiting for something new to come out.
flood
Re: Best monitor for FPS.
Post by flood » 01 Nov 2014, 18:34
fw900
or some other high end crt in good condition
:D
there isn't any hands down best. they all have disadvantages and it really depends on what you're looking for and what is important for you
Alamar
Post by Alamar » 01 Nov 2014, 19:51
Unfortunately from lcds VG248Q is the fastest (similiar are rog swift and LG 24GM77).
Edmond
Post by Edmond » 02 Nov 2014, 06:46
isnt it wonderful that there isnt a clear choice? ...
/sarcasm off
Ewok
Post by Ewok » 02 Nov 2014, 07:06
Which FPS games do you play? And how many frames per second do you get?
If you get a constant 144 FPS, and you still feel too much motion blur, then you need tu use a backlight strobing technology. The Asus VG248QE supports Lightboost.
If you get a lower framerate (such as 60 FPS), then you can try lowering the graphic options in order to get a higher framerate. If that isn't enough, then you need more graphics power. What's your current graphics card?
rootsoft
Post by rootsoft » 02 Nov 2014, 11:10
I'm getting over 144 FPS and tried the Lightboost tweak, but I can't feel a difference using it. It just makes everything a bit darker.. I have a GTX 560 and a i7 4790.
Edmond
Post by Edmond » 02 Nov 2014, 16:02
rootsoft wrote:I'm getting over 144 FPS and tried the Lightboost tweak, but I can't feel a difference using it. It just makes everything a bit darker.. I have a GTX 560 and a i7 4790.
If you dont see the benefits of lightboost then your choice is obvious - you want a gsync monitor.
You dont need to buy a new one even, i think your is the one which is moddable with gsync... if you can find the kit.
And you can freely skip the CRT recommendations too, because those are essentially perma lightboost monitors.
flood
Post by flood » 02 Nov 2014, 18:26
no point to gsync unless you dont like the tearing. which, for me at least, is completely invisible at those rates
imo it's too early to upgrade from the vg248qe to something else.
Ewok
Post by Ewok » 03 Nov 2014, 16:25
Wait, doesn't G-Sync behave like VSync for framerates above the refresh rate of the monitor?
Why would he need a G-Sync monitor?
Q83Ia7ta
Post by Q83Ia7ta » 03 Nov 2014, 20:13
Ewok wrote:Wait, doesn't G-Sync behave like VSync for framerates above the refresh rate of the monitor?
Because tearing at low fps is more noticeable.
