Help Figuring out if the PG27AQDP is worth it
AllNight
Post by AllNight » 23 Dec 2024, 14:58
So basically, I upgraded my PCs CPU and got a lot more FPS and wanna know if it is a good choice for my situation
Ryzen 5500
RX 6600
32 GB 3600MHZ corsair vengeance mem
Thermal Take Smart 500W PSU (had it for 1 yr and going, we paid less so we pray more :lol: )
to a Ryzen 5700X3D CPU upgrade, keeping everything else
using the asus tuf 165 hz VG27VH1B Monitor
because of this upgrade I can now reach an avg of 470 fps and low avg of 250fps in the one game i play often (fortnite), which made me wonder if the PG27AQDP would be able to be of use for me with my current specs and fps output
I also wonder if the PG27AQDP can run 1080p at 500hz or lower resolutions with the same high 480hz
I want these high FPS because of an unconfirmed belief that more FPS will reduce input delay because I see lower frame times
I'm also likely going to upgrade to a 30 series NVIDIA card in order to get Reflex and the advantages from fortnites input latency settings that AMD cannot use
