VRR range on 24G4XE (24G4) ?
Re: VRR range on 24G4XE (24G4) ?
Post by RealNC » 24 Dec 2024, 08:44
maxolini wrote:
23 Dec 2024, 16:03
So what fps limit should i use on 180hz ?
Whatever you want, as long as it's less than 180. On my 240Hz display,I cap to 90 because that's good enough for me.
Nvidia's Reflex cap for 180Hz is 170FPS. So according to Nvidia, anything up to 170 is "safe".
maxolini
Post by maxolini » 24 Dec 2024, 10:50
RealNC wrote:
24 Dec 2024, 08:44
maxolini wrote:
23 Dec 2024, 16:03
Thank you for the information.
maxolini
Post by maxolini » 25 Dec 2024, 18:13
Btw,if i use GSYNC with vsync off can i just cap it at 180hz globally from NVCP(even i think i causes some little lag in windows and in general or am i crazy) ???
Post by RealNC » 25 Dec 2024, 18:16
maxolini wrote:
25 Dec 2024, 18:13
You can. But there's gonna be tearing. 170 should basically have no tearing even with vsync off, unless the game has frame time variance (which vsync will fix.)
