my frametime goes up every time I kill. my frametime is also unstable. I get 360 stable fps, which drops to 300 every ms. I want you to check this for yourself.
About my settings for computer optimization
- Slender
Re: About my settings for computer optimization
alp15eren
You can look at thisalp15eren wrote: ↑14 Jan 2025, 10:57I did a test for CS2. There is a slowdown in certain parts of the video, not a stutter, but this problem is not caused by me. When I watch the original MP4 video, there is no such thing. Maybe it is due to the browser.
I have applications open in the background and I am downloading games via Steam.
https://www.youtube.com/watch?v=GD7FH7uO9Zs
JimCarry
you were 99% right these is my benchmark before and after.alp15eren wrote: ↑14 Jan 2025, 11:15The resizable bar setting does not make a difference in fps in CS2. But it causes a lot of trouble in some games, especially Call of Duty.JimCarry wrote: ↑14 Jan 2025, 11:10My sound was not in msi mode also i put it,and my vc was in msi just like yours.alp15eren wrote: ↑14 Jan 2025, 10:58The settings I mentioned may appear differently on each motherboard. I don't know why my sound is not on the MSI because when I install the driver normally, only my graphics card is in msi mode. I also remove it from msi mode.JimCarry wrote: ↑14 Jan 2025, 10:50I have pretty much the same settings as you except: i dont see "CPU PCIe ASPM Mode Control" and "PSS Support" in bios,also my Resizable Bar is Enabled.Can i ask why is your audio is not in msi ? also this is my msi what should i change ? and should i disable resize bar?
The resizable bar causes stutters on AMD systems (including Nvidia graphics cards and AMD processors). When I turn it off, I have a much better gaming experience.
can i ask you to run this https://steamcommunity.com/sharedfiles/ ... 3240880604 benchmark with "resize bar enabled and under it above 4g enabled" in bios. and then go in bios disabled it and do the test again.also i have amd cpu and rx 580 8gb but when i disabled resize bar i have only 256mb.Look the screen.
I do not recommend the map you posted. Because it gives very irrelevant results. The real test is to constantly check FPS, 1% and Frametime in a normal match.
i have only one question,when i enter the bios i have 3 options:
above 4g decoding
resize bar support
sr-iov support
so if i done it the right way like you said, and in the pictures below, only 4g decoding should be enabled ?
- g.GIF (47.43 KiB) Viewed 88539 times
- off.GIF (45.39 KiB) Viewed 88539 times
alp15eren
I think there will be no problem this wayJimCarry wrote: ↑14 Jan 2025, 11:41you were 99% right these is my benchmark before and after.alp15eren wrote: ↑14 Jan 2025, 11:15The resizable bar setting does not make a difference in fps in CS2. But it causes a lot of trouble in some games, especially Call of Duty.JimCarry wrote: ↑14 Jan 2025, 11:10My sound was not in msi mode also i put it,and my vc was in msi just like yours.alp15eren wrote: ↑14 Jan 2025, 10:58
above 4g decoding
resize bar support
sr-iov support
JimCarry
Ok thanks now the only thing left for me to do is untick msi mode for my gpu and audio and i am 1:1 like your settings right ?alp15eren wrote: ↑14 Jan 2025, 11:47I think there will be no problem this wayJimCarry wrote: ↑14 Jan 2025, 11:41you were 99% right these is my benchmark before and after.alp15eren wrote: ↑14 Jan 2025, 11:15The resizable bar setting does not make a difference in fps in CS2. But it causes a lot of trouble in some games, especially Call of Duty.JimCarry wrote: ↑14 Jan 2025, 11:10
above 4g decoding
resize bar support
sr-iov support
alp15eren
I get better performance this way. I don't know how it would be for youJimCarry wrote: ↑14 Jan 2025, 11:48Ok thanks now the only thing left for me to do is untick msi mode for my gpu and audio and i am 1:1 like your settings right ?alp15eren wrote: ↑14 Jan 2025, 11:47I think there will be no problem this wayJimCarry wrote: ↑14 Jan 2025, 11:41you were 99% right these is my benchmark before and after.alp15eren wrote: ↑14 Jan 2025, 11:15
above 4g decoding
resize bar support
sr-iov support
JimCarry
thanks can you share the script for all of this? and also i have pretty much same settings without the affinity stuff,and when i edit the power plan option "Interrupt Steering mode" why you think should be to procesor one not default?alp15eren wrote: ↑14 Jan 2025, 11:56I get better performance this way. I don't know how it would be for youJimCarry wrote: ↑14 Jan 2025, 11:48Ok thanks now the only thing left for me to do is untick msi mode for my gpu and audio and i am 1:1 like your settings right ?alp15eren wrote: ↑14 Jan 2025, 11:47I think there will be no problem this wayJimCarry wrote: ↑14 Jan 2025, 11:41
above 4g decoding
resize bar support
sr-iov support
alp15eren
If I'm not mistaken, making it Processor 1 moves some interrupts from CPU0 to CPU1. I've seen this in latencymon and xperf. Latencymon also reduces the latency even more.JimCarry wrote: ↑14 Jan 2025, 11:59thanks can you share the script for all of this? and also i have pretty much same settings without the affinity stuff,and when i edit the power plan option "Interrupt Steering mode" why you think should be to procesor one not default?
Code: Select all
@echo off
:gotPrivileges
REM Türkçe karakter desteği
chcp 65001 > nul
REM 1. Kayıt Defteri Ayarları
reg add "HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\AutoplayHandlers" /v DisableAutoplay /t REG_DWORD /d 1 /f
reg add "HKLM\SOFTWARE\Microsoft\WindowsRuntime\ActivatableClassId\Windows.Gaming.GameBar.PresenceServer.Internal.PresenceWriter" /v ActivationType /t REG_DWORD /d 0 /f
reg add "HKLM\SYSTEM\CurrentControlSet\Control\DeviceGuard" /v EnableVirtualizationBasedSecurity /t REG_DWORD /d 0 /f
reg add "HKLM\SYSTEM\CurrentControlSet\Control\Session Manager\kernel" /v GlobalTimerResolutionRequests /t REG_DWORD /d 1 /f
REM 2. Komut İstemcisi Ayarları
powercfg /h off
powercfg -setactive 8c5e7fda-e8bf-4a96-9a85-a6e23a8c635c
powercfg /SETACVALUEINDEX SCHEME_CURRENT 48672f38-7a9a-4bb2-8bf8-3d85be19de4e 2bfc24f9-5ea2-4801-8213-3dbae01aa39d 6
REM 3. RECALL Devre Dışı Bırak
Dism /Online /Disable-Feature /FeatureName:Recall
REM İşlem tamamlandı bildirimi
echo İşlemler başarıyla tamamlandı.
pause-
JimCarry
thanks i will save it for next reinstall/update of windows.alp15eren wrote: ↑14 Jan 2025, 12:08If I'm not mistaken, making it Processor 1 moves some interrupts from CPU0 to CPU1. I've seen this in latencymon and xperf. Latencymon also reduces the latency even more.
Run these commands with PowerRunCode: Select all
@echo off :gotPrivileges REM Türkçe karakter desteği chcp 65001 > nul REM 1. Kayıt Defteri Ayarları reg add "HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\AutoplayHandlers" /v DisableAutoplay /t REG_DWORD /d 1 /f reg add "HKLM\SOFTWARE\Microsoft\WindowsRuntime\ActivatableClassId\Windows.Gaming.GameBar.PresenceServer.Internal.PresenceWriter" /v ActivationType /t REG_DWORD /d 0 /f reg add "HKLM\SYSTEM\CurrentControlSet\Control\DeviceGuard" /v EnableVirtualizationBasedSecurity /t REG_DWORD /d 0 /f reg add "HKLM\SYSTEM\CurrentControlSet\Control\Session Manager\kernel" /v GlobalTimerResolutionRequests /t REG_DWORD /d 1 /f REM 2. Komut İstemcisi Ayarları powercfg /h off powercfg -setactive 8c5e7fda-e8bf-4a96-9a85-a6e23a8c635c powercfg /SETACVALUEINDEX SCHEME_CURRENT 48672f38-7a9a-4bb2-8bf8-3d85be19de4e 2bfc24f9-5ea2-4801-8213-3dbae01aa39d 6 REM 3. RECALL Devre Dışı Bırak Dism /Online /Disable-Feature /FeatureName:Recall REM İşlem tamamlandı bildirimi echo İşlemler başarıyla tamamlandı. pause
can you explain this:
is this Interrupt Steering mode to Processor 1
alp15eren
The first code sets the power plan to High Performance.JimCarry wrote: ↑14 Jan 2025, 12:23thanks i will save it for next reinstall/update of windows.alp15eren wrote: ↑14 Jan 2025, 12:08If I'm not mistaken, making it Processor 1 moves some interrupts from CPU0 to CPU1. I've seen this in latencymon and xperf. Latencymon also reduces the latency even more.
The second code sets the Interrupt Management Mode to Processor 1 in the active power plan
Code: Select all
0 - 00000000 - Default - Default
1 - 00000001 - Any processor - Route interrupts to any processor
2 - 00000002 - Any unparked processor with time delay - Route interrupts to any unparked processor with time delay
3 - 00000003 - Any unparked processor - Route interrupts to any unparked processor
4 - 00000004 - Lock Interrupt Routing - Lock Interrupt Routing
5 - 00000005 - Processor 0 - Route interrupts to Processor 0
6 - 00000006 - Processor 1 - Route interrupts to Processor 1
