About my settings for computer optimization
JimCarry
Re: About my settings for computer optimization
Post by JimCarry » 14 Jan 2025, 12:29
alp15eren wrote: ↑
14 Jan 2025, 12:26
JimCarry wrote: ↑
14 Jan 2025, 12:23
alp15eren wrote: ↑
14 Jan 2025, 12:08
JimCarry wrote: ↑
14 Jan 2025, 11:59
thanks can you share the script for all of this? and also i have pretty much same settings without the affinity stuff,and when i edit the power plan option "Interrupt Steering mode" why you think should be to procesor one not default?
If I'm not mistaken, making it Processor 1 moves some interrupts from CPU0 to CPU1. I've seen this in latencymon and xperf. Latencymon also reduces the latency even more.
Code: Select all
@echo off
:gotPrivileges
REM Türkçe karakter desteği
chcp 65001 > nul
REM 1. Kayıt Defteri Ayarları
reg add "HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\AutoplayHandlers" /v DisableAutoplay /t REG_DWORD /d 1 /f
reg add "HKLM\SOFTWARE\Microsoft\WindowsRuntime\ActivatableClassId\Windows.Gaming.GameBar.PresenceServer.Internal.PresenceWriter" /v ActivationType /t REG_DWORD /d 0 /f
reg add "HKLM\SYSTEM\CurrentControlSet\Control\DeviceGuard" /v EnableVirtualizationBasedSecurity /t REG_DWORD /d 0 /f
reg add "HKLM\SYSTEM\CurrentControlSet\Control\Session Manager\kernel" /v GlobalTimerResolutionRequests /t REG_DWORD /d 1 /f
REM 2. Komut İstemcisi Ayarları
powercfg /h off
powercfg -setactive 8c5e7fda-e8bf-4a96-9a85-a6e23a8c635c
powercfg /SETACVALUEINDEX SCHEME_CURRENT 48672f38-7a9a-4bb2-8bf8-3d85be19de4e 2bfc24f9-5ea2-4801-8213-3dbae01aa39d 6
REM 3. RECALL Devre Dışı Bırak
Dism /Online /Disable-Feature /FeatureName:Recall
REM İşlem tamamlandı bildirimi
echo İşlemler başarıyla tamamlandı.
pause
Run these commands with PowerRun
thanks i will save it for next reinstall/update of windows.
can you explain this:
is this Interrupt Steering mode to Processor 1
The first code sets the power plan to High Performance.
The second code sets the Interrupt Management Mode to Processor 1 in the active power plan
Code: Select all
0 - 00000000 - Default - Default
1 - 00000001 - Any processor - Route interrupts to any processor
2 - 00000002 - Any unparked processor with time delay - Route interrupts to any unparked processor with time delay
3 - 00000003 - Any unparked processor - Route interrupts to any unparked processor
4 - 00000004 - Lock Interrupt Routing - Lock Interrupt Routing
5 - 00000005 - Processor 0 - Route interrupts to Processor 0
6 - 00000006 - Processor 1 - Route interrupts to Processor 1
Thanks man.and lastly what is that?
alp15eren
Post by alp15eren » 14 Jan 2025, 12:32
JimCarry wrote: ↑
14 Jan 2025, 12:29
alp15eren wrote: ↑
14 Jan 2025, 12:26
JimCarry wrote: ↑
14 Jan 2025, 12:23
alp15eren wrote: ↑
14 Jan 2025, 12:08
Code: Select all
@echo off
:gotPrivileges
chcp 65001 > nul
powercfg /h off
pause
Code: Select all
I turn off the Windows Recall feature. It has nothing to do with performance. But the security risk is too high. It takes a screenshot of your screen every second and sends it to Microsoft. There are security vulnerabilities.
JimCarry
Post by JimCarry » 14 Jan 2025, 12:37
alp15eren wrote: ↑
14 Jan 2025, 12:32
JimCarry wrote: ↑
14 Jan 2025, 12:29
alp15eren wrote: ↑
14 Jan 2025, 12:26
JimCarry wrote: ↑
14 Jan 2025, 12:23
Code: Select all
Thanks for sharing and explaining.xanatres peek
i run the in cmd / powershell and says this:
alp15eren
Post by alp15eren » 14 Jan 2025, 12:41
JimCarry wrote: ↑
14 Jan 2025, 12:37
alp15eren wrote: ↑
14 Jan 2025, 12:32
JimCarry wrote: ↑
14 Jan 2025, 12:29
alp15eren wrote: ↑
14 Jan 2025, 12:26
Code: Select all
Recall only 24H2
JimCarry
Post by JimCarry » 14 Jan 2025, 12:51
alp15eren wrote: ↑
14 Jan 2025, 12:41
JimCarry wrote: ↑
14 Jan 2025, 12:37
alp15eren wrote: ↑
14 Jan 2025, 12:32
JimCarry wrote: ↑
14 Jan 2025, 12:29
Recall only 24H2
so mine is 22H2 and it will not work right thats why when i type cmd / powershell "Dism /Online /Disable-Feature /FeatureName:Recall" it gives me the error in the picture?
also can you read this thread viewtopic.php?f=10&t=13779 its about the option interupt steering mode sticky says it should another option,also there is a dword in kernel ?
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\kernel]
"InterruptSteeringDisabled"=dword:00000001
alp15eren
Post by alp15eren » 14 Jan 2025, 12:56
JimCarry wrote: ↑
14 Jan 2025, 12:51
alp15eren wrote: ↑
14 Jan 2025, 12:41
JimCarry wrote: ↑
14 Jan 2025, 12:37
alp15eren wrote: ↑
14 Jan 2025, 12:32
Recall only 24H2
Yes
I saw this thread. I'm not 100% sure about the processor 1 part. Honestly I'm more than happy with the current fps and latency so I didn't change it. Even in CS2 I can play with very stable frame times.
JimCarry
Post by JimCarry » 14 Jan 2025, 13:02
alp15eren wrote: ↑
14 Jan 2025, 12:56
JimCarry wrote: ↑
14 Jan 2025, 12:51
alp15eren wrote: ↑
14 Jan 2025, 12:41
JimCarry wrote: ↑
14 Jan 2025, 12:37
Recall only 24H2
Yes
that option has so many settings i will try to Processor 1,and not add the kernel dword. thanks again for sharing.
JimCarry
Post by JimCarry » 15 Jan 2025, 04:31
Hi again one last question :D one this pic you re showing download/file.php?id=5392 why is NumberOfReceiveQueues 1?
alp15eren
Post by alp15eren » 15 Jan 2025, 05:18
JimCarry wrote: ↑
15 Jan 2025, 04:31
That code briefly shows how many CPUs the Ethernet can work on. I made that value 1 so that it only works on CPU3. If the original value was 4, it would also work on even-numbered CPUs. I chose CPU3, so the even numbers after that.
Like CPU3, CPU4, CPU6 and CPU8.
If I had left the Ethernet in its original state instead of CPU3,
It would work on CPU0, CPU2, CPU4 and CPU 6.
JimCarry
Post by JimCarry » 15 Jan 2025, 09:17
alp15eren wrote: ↑
15 Jan 2025, 05:18
JimCarry wrote: ↑
15 Jan 2025, 04:31
ok thnaks i subscribed to your youtube,so i have ryzen 5 7600x and in your opinion wich one should i choose ?
