Everything about latency. This section is mainly user/consumer discussion. (Peer-reviewed scientific discussion should go in Laboratory section). Tips, mouse lag, display lag, game engine lag, network lag, whole input lag chain, VSYNC OFF vs VSYNC ON, and more!
Input Lag Articles on Blur Busters.
Post
by Slender » 19 Jan 2025, 05:38
dervu wrote: ↑19 Jan 2025, 04:41
agendarsky wrote: ↑18 Jan 2025, 23:42
dervu wrote: ↑18 Jan 2025, 03:56
Are you sure you are not mistaking it for GPU usage?
ECC errors show in count, not in percentage and you have to turn on ECC on GPU to make it appear.
how do you turn ecc on gpu? where can you see status of it?
In nvidia panel if your card supports it:
any difference on / off?
ahead
Post
by ahead » 19 Jan 2025, 05:40
no difference, after restart PC checkbox again will be empty
