Two settings that eliminated a lot of mouse heaviness for me
rooy
Re: Two settings that eliminated a lot of mouse heaviness for me
Post by rooy » 22 Jan 2025, 15:27
The value is protected by Secure Boot policy and cannot be modified or deleted.
JimCarry
Post by JimCarry » 22 Jan 2025, 16:14
rooy wrote:
22 Jan 2025, 15:27
I use to have this message i think you must turn off something in bios but i forgot what was it.Look @kriegsnake snake post after he apply it.
Hyote
Post by Hyote » 22 Jan 2025, 21:11
bleya99 wrote:
22 Jan 2025, 11:22
Hyote wrote:
20 Jan 2025, 03:29
Revived this as well because I changed the DirectX settings and now they give me INSANELY snappy input.
Have you just reapplied your settings posted above or have you tweaked something additionally?
[HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Microsoft\DirectDraw]
"DisableAGPSupport"=dword:00000001
"DisableInactivate"=dword:00000001
"DisableMMX"=dword:00000001
"DisableNoSysLock"=dword:00000001
"EmulationOnly"=dword:00000001
Only "EmulationOnly" was changed previously. Also keep in mind how this can break some games (as usual with my posts) but the ones that run have no issues.
ahead
Post by ahead » 24 Jan 2025, 02:02
ROFL, go ahead and ban me if you want. But seriously, you clueless idiots—first of all, DirectDraw was used for 2D games. Second, it hasn’t been used in over 20 years and was replaced by other technologies. I’m honestly done tolerating this level of stupidity.
You know why you never get answers? Because you can’t call idiots what they truly are. That’s the fundamental problem with this place.
Hyote
Post by Hyote » 24 Jan 2025, 04:18
ahead wrote:
24 Jan 2025, 02:02
I claim to not know things when I do not know them. Most of this place is about speculation and you are contributing to toxicity because you can't stand seeing something you think is insensible. You explain how this technology is not in use, etc. but that does not answer if it can cause latency issues regardless. You did not test this personally and base your knowledge on how things SHOULD work.
Post by Slender » 24 Jan 2025, 04:28
Hyote wrote:
24 Jan 2025, 04:18
ahead wrote:
24 Jan 2025, 02:02
true
dervu
Post by dervu » 24 Jan 2025, 05:29
Hyote wrote:
24 Jan 2025, 04:18
ahead wrote:
24 Jan 2025, 02:02
How can something not being used cause latency?
Ryzen 7950X3D / MSI GeForce RTX 4090 Gaming X Trio / ASUS TUF GAMING X670E-PLUS / 2x16GB DDR5@6000 G.Skill Trident Z5 RGB / Dell Alienware AW3225QF / Logitech G PRO X SUPERLIGHT / SkyPAD Glass 3.0 / Wooting 60HE / DT 700 PRO X || EMI Input lag issue survivor (source removed) 8-)
ahead
Post by ahead » 24 Jan 2025, 05:39
DirectDraw has not been used for a long time. It was meant for 2D graphics in the past, not 3D. Criticizing me for being toxic is one thing, but posts like yours, filled with poor solutions, have driven away knowledgeable people from this space.
Hyote
Post by Hyote » 24 Jan 2025, 05:58
dervu wrote:
24 Jan 2025, 05:29
Hyote wrote:
24 Jan 2025, 04:18
ahead wrote:
24 Jan 2025, 02:02
Something that is thought to be unused is what I meant but there is no need to get into mental gymnastics here.
Hyote
Post by Hyote » 24 Jan 2025, 06:16
ahead wrote:
24 Jan 2025, 05:39
I worded things in my original post almost 1:1 with what you wrote in these comments but it still seems like a huge issue for you. Maybe the post is not up to some imagined standards but this is still a forum about experimental things. I don't know if I'm also slightly off base here but I don't see how information that is neutral at worst can cause someone to stop visiting this site. If you lose hope because you don't see sensible posts every single time you should reevaluate why this place might exist. We are trying to tackle problems here which are not even talked or even thought about so there is no clear path to any solution. That is exactly why I write some lower quality posts because I remember how I came across some settings that would not have been discovered without someone trying and sharing them.
