Significant RetroArch BFI Update
sodaboy581
Re: Significant RetroArch BFI Update
Post by sodaboy581 » 03 Jun 2024, 15:30
Man, just coming back here to post that I'm sad that I can't get BFI working properly with HDR enabled with RetroArch.
RetroArch and HDR is fine on my setup (running at 180hz), but when I enable BFI it's like the colors go dim, pop, dim, pop randomly on top of also doing BFI.
Wonder if anyone else has got RetroArch + HDR + BFI working correctly.
I can either do RetroArch + BFI, or RetroArch + HDR, but not everything at the same time. Boooo..
Here's a video of what it looks like:
https://youtube.com/shorts/OviHTsOdkXA?feature=share
EDIT: I believe this is actually not a RetroArch bug and a result of the local dimming "feature" of the HP Omen 27 qs being a bit laggy.
chocobeau
Post by chocobeau » 02 Jul 2024, 11:53
sodaboy581 wrote:
03 Jun 2024, 15:30
The review from rtings mention it : https://www.rtings.com/monitor/reviews/ ... #test_1387
FlameOnion
Post by FlameOnion » 02 Feb 2025, 11:34
hickmankay wrote:
22 Apr 2024, 03:36
FlameOnion wrote:
17 Apr 2024, 07:17
How about BFI choices for pal/50hz, 100hz, 150,hz, 200hz, etc. I used nightly 2024-04-17_RetroArch.7z, and did not see them.
With those frequencies, which one is better for you? I'm looking into it
Still no PAL BFI.(preferring 150hz and 250hz to prevent image retention)
