I was able to overclock to 146hz with the NVIDIA Control Panel..
I did not make a difference for me and it just made pixels look bigger.
ASUS VG248QE
Re: ASUS VG248QE
Lightboost and Benq BR doesn't cause input lag at all. it's not noticeable.
Any input lag you feel would be simply vsync itself. You can just disable vsync and cap the framerate (if the game allows it) or just play without vaync.
Re: ASUS VG248QE
liesFalkentyne wrote:Lightboost and Benq BR doesn't cause input lag at all. it's not noticeable.
Re: ASUS VG248QE
Not a lie at all.
I toggle on and off and there's no noticeable difference.
There IS a difference when I toggle vsync on and off. That's noticeable (although not bad enough to affect my play, although 144hz vsync on feels better than 100hz vsync on, but framerate drops under 144, affect me --more-- than slightly higher input lag at 100, so I keep it at 100hz
- masterotaku
Re: ASUS VG248QE
Even if they have a bit more input lag, I prefer blur reduction/lightboost over no strobing because the image is more stable. What I mean is that here, http://testufo.com/#test=photo&photo=al ... &height=-1 , without strobing the upper part of the screen is ahead of the bottom part, so the image looks oblique. With strobing, it looks perfectly straight (elements from top to bottom are aligned).
Like going from this (exaggeration):
aaaaaaaaa
aaaaaaaa
aaaaaaa
To this:
aaaaaaa
aaaaaaa
aaaaaaa
It has more lag because the image is aligned to what's happening at the bottom, so you have the same input lag across the entire screen.
aaaaaaaaa
aaaaaaaa
aaaaaaa
To this:
aaaaaaa
aaaaaaa
aaaaaaa
Monitor: Asus PG278QR
