[EMI] 1500mV When computer is running!!!
- kriegsnake
Re: [EMI] 1500mV When computer is running!!!
Good day. Those filters are kinda expensive for eu countries, starting from 60$+15$ delivery , should i even bother to buy one to check if there is any difference? I mean you guys bought 2 then used 4, am I good to go with one in the cord?
Thatweirdinputlag
If you want the results of my personal experience, since I bought 6 EU ones, that did cost me a fortune with international shipping and import fees, it did not help. desync, sluggish game feel, heavy character movement, uncontrollable spray patterns are still pretty much the same. I do however have less than 30-40mVptp all around the house, if it even matters at this point lol.kriegsnake wrote: β30 Aug 2023, 07:07Good day. Those filters are kinda expensive for eu countries, starting from 60$+15$ delivery , should i even bother to buy one to check if there is any difference? I mean you guys bought 2 then used 4, am I good to go with one in the cord?
Kiujind
Fixed!
Hybrid inverter + 200ah lifepo4 battery. Playing off grid is definitely the easiest but expensive fix.
- Slender
skkiNN
bump this thread!!
- Slender
skkiNN
You sure man? Kingsaman saw his PSU was emitting 1500mV. Then he replaced with a H1200i and he said mV went down to 600. I think it must have an effect. I dont talk about greenwave filters.. If the problem is psu with such an high mV, filters wont do anything ofc because the source is the PSU. Im want seek deep into this
- Slender
850w platinum + 13700kf / 3070ti : 1500-1850mvskkiNN wrote: β26 Feb 2025, 10:37You sure man? Kingsaman saw his PSU was emitting 1500mV. Then he replaced with a H1200i and he said mV went down to 600. I think it must have an effect. I dont talk about greenwave filters.. If the problem is psu with such an high mV, filters wont do anything ofc because the source is the PSU. Im want seek deep into this
650w aerocool + 8700k + 1060 : not adds any mv (work same bad like 850w build)
If any frequencies affect our problems, then this is the range of 100hz-2000hz.
skkiNN
What u mean? Did u try with 850w plat and 650w aero?Slender wrote: β26 Feb 2025, 10:46850w platinum + 13700kf / 3070ti : 1500-1850mvskkiNN wrote: β26 Feb 2025, 10:37You sure man? Kingsaman saw his PSU was emitting 1500mV. Then he replaced with a H1200i and he said mV went down to 600. I think it must have an effect. I dont talk about greenwave filters.. If the problem is psu with such an high mV, filters wont do anything ofc because the source is the PSU. Im want seek deep into this
Then we should try corsair hx1200i and Seasonic PRIME TX-1000, he said mV are way lower with that products..
- Slender
i mean 100 mv vs 1500(1850) not affectskkiNN wrote: β27 Feb 2025, 15:02What u mean? Did u try with 850w plat and 650w aero?Slender wrote: β26 Feb 2025, 10:46850w platinum + 13700kf / 3070ti : 1500-1850mvskkiNN wrote: β26 Feb 2025, 10:37You sure man? Kingsaman saw his PSU was emitting 1500mV. Then he replaced with a H1200i and he said mV went down to 600. I think it must have an effect. I dont talk about greenwave filters.. If the problem is psu with such an high mV, filters wont do anything ofc because the source is the PSU. Im want seek deep into this
