There are no >360hz TN displays which aren't made by Zowie as of the time of writing.NSR333 wrote: ↑02 Mar 2025, 08:01Does anyone have any recommendations for a 24.5” 360HZ TN panel that isn’t the Zowie? Ideally looking to spend max £400. I play counter strike at a high competitive level so need the best monitor.
If the Zowie XL2566K really is the best I will save for it, but I just need some opinions from people who know more than me before I spend £600 on a monitor. Thanks in advance!
The XL2566K is a bad purchase as well, due to the added processing delay over other implementations.
Consider the XL2566X+ instead, as it sports the new E-TN panels which have better G2G response times over the old (XL2566K) panel.
