Does CTA-861 triple buffer frames?
Re: Does CTA-861 triple buffer frames?
The thing is, I use a custom pointer curve and it doesn't get disabled by any of these settings, including MouseAccel and RawInput in HCKU/Control Panel/Mouse.
It's good that I can keep my accel on but unfortunately this most likely shows the ineffectiveness of the reg keys.
so op post placebe except for cru ?Hyote wrote: ↑06 Mar 2025, 18:07The thing is, I use a custom pointer curve and it doesn't get disabled by any of these settings, including MouseAccel and RawInput in HCKU/Control Panel/Mouse.
I don't know but I'll keep adding game exe files into regedit like that because there haven't been any negative effects so far.JimCarry wrote: ↑06 Mar 2025, 19:01so op post placebe except for cru ?Hyote wrote: ↑06 Mar 2025, 18:07The thing is, I use a custom pointer curve and it doesn't get disabled by any of these settings, including MouseAccel and RawInput in HCKU/Control Panel/Mouse.
I use Raw Accel aswell on purpose! it doesn't get disabled because it is a mousefilter most likely that is directly integraded in the driver you can look that up by going to your device managers mouse and under driver details you will see there is rawaccel or custom curve in the drivers directory...Hyote wrote: ↑06 Mar 2025, 18:07The thing is, I use a custom pointer curve and it doesn't get disabled by any of these settings, including MouseAccel and RawInput in HCKU/Control Panel/Mouse.
sadly they are not really documented by microsoft or any other forum thats why it took me so long to find themBrutek_Vladimir wrote: ↑06 Mar 2025, 16:07I dont think you can provide sources or links for these "tweaks".Mighty wrote: ↑02 Mar 2025, 12:25probably allot of you who searched for floaty mouse fixes heard of the Windows 8 Tweak with in the Appcompat/layers Folder in Regedit... well the thing is most users use this tweak in the wrong way because its told commonly to put the path to exe file of your application as name of the REG SZ key but you dont simply type in NoDTToDITMouseBatch because it doesnt' work this way in Windows 10 and 11. If you want to apply you have to type NoDTToDITMouseBatch=1 for it to work.
Fun Fact. If you make a REG MULTI SZ there you can apply multiple tweaks for any games you want to make Mouse Movement insanely responsive and HITREG soo good i'll leave them here as i know a lot of you guys just like me are going insane about this topic.
this is the list of tweaks i use in CS2 for example:
NtTNoBatch=1
NTTThreshold=0
DisableProcessWindowsMouseAcceleration=1
NoGDIHWAcceleration=1
NoAsyncInput=1
DisableMouseAcceleration=1
DisableFullscreenOptimizations=1
NoLowLevelHooks=1
NoBufferedInput=1
DisableDpiScaling=1
MouseNoSpeedScaling=1
NoAsyncRender=1
ForceThreadedInput=0
NoHyperThreadingInput=1
DisableInputPrediction=1
DisableVSync=1
DisableGameDVR=1
DisableMouseSmoothing=1
NoInputLagCompensation=0
NoSwapChainOverride=1
NoBatch=1
FixRelativeMouseMovement=1
NoLegacyMouse=0
NoForegroundLockTimeout=1
NoTimerResolutionOverride=1
DisableSystemTimers=1
DisableBackgroundTaskOptimization=1
DisableMulticoreScaling=1
NoTiledRendering=1
NoFlipQueue=1
NoSpeedScaling=1
DisableRawInputBuffer=1
EnableDirectInput=0
EnableLegacyMouseMode=0
EnablePS2RateOverride=0
ForceHighPollingRate=1
ForceUSBHIDMode=1
ForceRawInput=1
But shot, surprise me![]()
Heres a Quick Video how cs2 looks on my setup now
https://www.youtube.com/watch?v=cSC-YYYjL5Y
LAYERS COMMANDS USED IN THE VIDEO (could be possible that some are twice i am in a hurry
NtTNoBatch=1
NTTThreshold=0
NoAsyncInput=1
NoLowLevelHooks
NoBufferedInput
DisableDpiScaling
DisableHIDInputBuffer=1
NoUSBQueueing=1
NoKernelMouseProcessing=1
ForceDirectMouseDriverExecution=1
NoAsyncRender
DisableInputPrediction=0
DisableVSync=1
DisableGameDVR=1
NoBatch=1
NoLegacyMouse=0
NoTimerResolutionOverride=0
DisableSystemTimers=0
DisableMulticoreScaling=0
NoTiledRendering=1
NoFlipQueue=1
NoSpeedScaling=1
EnableDirectInput=0
ForceUSBHIDMode=1
ForceRawInput=1
NoMouseRateOverride=1
NoUSBSelectiveSuspend=1
DisableHIDPowerSave=1
DisableUSBBuffering=1
DisableInputProcessingQueue=1
DisableDynamicTick=1
NoSMT=1
DisableKernelPaging=1
ForceHPET=1
NoWDDMOverlay=1
DisablePrefetch=1
NoNagleAlgorithm=1
DisableReceiveWindowAutoTuning=1
NoQoSReservableBandwidth=1
NoAutoDNS=1
NoUSBInterruptModeration=1
NoMouseProcessing=1
NoBackgroundMousePriority=1
DisableMouseAccelerationKernel=1
DisableHIDPollingRateLimit=1
NoCPULoadBalancing=1
ForceMaxPerformance=1
NoDynamicCoreScaling=1
DisableEnergySavingCStates=1
ForceNoKernelPaging=1
DisableAllDesktopComposition=1
NoFrameBufferQueue=1
DisableVRR=1
NoDeferredRendering=1
NoWindowsPacketScheduling=1
DisableNagleV2=1
NoBackgroundNetworkTasks=1
DisableWiFiPowerSaving=1
NoAutoTCPBufferScaling=1
DisableUACVirtualization=1
NoKernelModeDrivers=1
DisableExplorerProcessGrouping=1
DisableWindowsErrorReporting=1
DisableSuperfetch=1
DisableHIDIdleTimeout=1
ForceUSBHighPriority=1
NoExtraMouseProcessing=1
DisableHIDPollingJitter=1
DisableKernelMemoryPaging=1
NoCStateTransitions=1
DisableIRQSharing=1
DisableMemoryZeroing=1
NoDXGIFrameQueue=1
DisableDWMScaling=1
DisablePresentBuffering=1
NoPacketCoalescing=1
DisableTCPReassembly=1
NoWiFiRoaming=1
DisableTelemetryAndTracking=1
NoWindowsEventLogging=1
DisablePowerThrottling=1
EnableSubPixelProcessing=1
ForceRawInputPrecision=1
NoCursorSmoothing=1
DisablePointerRounding=1
DisableUSBPollingJitter=1
NoHIDInputDelay=1
ForceFixedPollingRate=1
NoUSBInterruptDelays=1
NoForcedMouseSmoothing=1
DisableUSBNoiseFiltering=1
ForceHighPrecisionMouseTimers=1
NoUSBQueueing=1
NtTNoBatch=1
NTTThreshold=0
NoAsyncInput=1
NoLowLevelHooks
NoBufferedInput
DisableDpiScaling
NoUSBQueueing=1
NoAsyncRender
DisableVSync=1
DisableGameDVR=1
NoBatch=1
NoLegacyMouse=0
NoTiledRendering=1
NoFlipQueue=1
NoSpeedScaling=1
EnableDirectInput=0
ForceUSBHIDMode=1
ForceRawInput=1
NoSMT=1
ForceHPET=1
NoWDDMOverlay=1
DisablePrefetch=1
NoNagleAlgorithm=1
NoAutoDNS=1
NoMouseProcessing=1
DisableVRR=1
DisableNagleV2=1
DisableSuperfetch=1
DisableIRQSharing=1
NoDXGIFrameQueue=1
DisableDWMScaling=1
NoWiFiRoaming=1
NoCursorSmoothing=1
NoHIDInputDelay=1
NoUSBQueueing=1
I'm using the values for Enhanced Pointer Precision, just slightly modified.Mighty wrote: ↑06 Mar 2025, 20:14I use Raw Accel aswell on purpose! it doesn't get disabled because it is a mousefilter most likely that is directly integraded in the driver you can look that up by going to your device managers mouse and under driver details you will see there is rawaccel or custom curve in the drivers directory...Hyote wrote: ↑06 Mar 2025, 18:07The thing is, I use a custom pointer curve and it doesn't get disabled by any of these settings, including MouseAccel and RawInput in HCKU/Control Panel/Mouse.
It's good that I can keep my accel on but unfortunately this most likely shows the ineffectiveness of the reg keys.![]()
MouseSpeed 1
MouseThreshold1 6.7
MouseThreshold2 10
Only games with raw input override them.
Not trying to be rude - but that just might be the single most pointless thing ive ever watchedMighty wrote: ↑06 Mar 2025, 23:01Heres a Quick Video how cs2 looks on my setup now
LAYERS COMMANDS USED IN THE VIDEO (could be possible that some are twice i am in a hurry![]()
NtTNoBatch=1
NTTThreshold=0
NoAsyncInput=1
NoLowLevelHooks
NoBufferedInput
DisableDpiScaling
NoUSBQueueing=1
NoAsyncRender
DisableVSync=1
DisableGameDVR=1
NoBatch=1
NoLegacyMouse=0
NoTiledRendering=1
NoFlipQueue=1
NoSpeedScaling=1
EnableDirectInput=0
ForceUSBHIDMode=1
ForceRawInput=1
NoSMT=1
ForceHPET=1
NoWDDMOverlay=1
DisablePrefetch=1
NoNagleAlgorithm=1
NoAutoDNS=1
NoMouseProcessing=1
DisableVRR=1
DisableNagleV2=1
DisableSuperfetch=1
DisableIRQSharing=1
NoDXGIFrameQueue=1
DisableDWMScaling=1
NoWiFiRoaming=1
NoCursorSmoothing=1
NoHIDInputDelay=1
NoUSBQueueing=1
i am also deleting the reg key,untill someone does benchmarks before and after,and some source for the tweaks.mojosan wrote: ↑07 Mar 2025, 07:20Not trying to be rude - but that just might be the single most pointless thing ive ever watchedMighty wrote: ↑06 Mar 2025, 23:01Heres a Quick Video how cs2 looks on my setup now
NtTNoBatch=1
NTTThreshold=0
NoAsyncInput=1
NoLowLevelHooks
NoBufferedInput
DisableDpiScaling
NoUSBQueueing=1
NoAsyncRender
DisableVSync=1
DisableGameDVR=1
NoBatch=1
NoLegacyMouse=0
NoTiledRendering=1
NoFlipQueue=1
NoSpeedScaling=1
EnableDirectInput=0
ForceUSBHIDMode=1
ForceRawInput=1
NoSMT=1
ForceHPET=1
NoWDDMOverlay=1
DisablePrefetch=1
NoNagleAlgorithm=1
NoAutoDNS=1
NoMouseProcessing=1
DisableVRR=1
DisableNagleV2=1
DisableSuperfetch=1
DisableIRQSharing=1
NoDXGIFrameQueue=1
DisableDWMScaling=1
NoWiFiRoaming=1
NoCursorSmoothing=1
NoHIDInputDelay=1
NoUSBQueueing=1
Where exactly did you get all these, if Microsoft doesn’t document them?Mighty wrote: ↑06 Mar 2025, 23:01Heres a Quick Video how cs2 looks on my setup now
NtTNoBatch=1
NTTThreshold=0
NoAsyncInput=1
NoLowLevelHooks
NoBufferedInput
DisableDpiScaling
NoUSBQueueing=1
NoAsyncRender
DisableVSync=1
DisableGameDVR=1
NoBatch=1
NoLegacyMouse=0
NoTiledRendering=1
NoFlipQueue=1
NoSpeedScaling=1
EnableDirectInput=0
ForceUSBHIDMode=1
ForceRawInput=1
NoSMT=1
ForceHPET=1
NoWDDMOverlay=1
DisablePrefetch=1
NoNagleAlgorithm=1
NoAutoDNS=1
NoMouseProcessing=1
DisableVRR=1
DisableNagleV2=1
DisableSuperfetch=1
DisableIRQSharing=1
NoDXGIFrameQueue=1
DisableDWMScaling=1
NoWiFiRoaming=1
NoCursorSmoothing=1
NoHIDInputDelay=1
NoUSBQueueing=1
