I completely fixed the desync and hit reg.
gideonmontes
Re: I completely fixed the desync and hit reg.
Post by gideonmontes » 14 Mar 2025, 00:51
Slender wrote: ↑
14 Mar 2025, 00:34
gideonmontes wrote: ↑
14 Mar 2025, 00:22
JimCarry wrote: ↑
13 Mar 2025, 13:58
thousend12345 wrote: ↑
13 Mar 2025, 05:55
not work, just 0 result
ok,so op post placebo i got you back to 2.5gbps,to op as i shown in the picture above i did try it / change it.but i did not feel any diffrence(cs2) maybe someone who is smarter can do bencmarks / test and prove that is placebo o maybe not ? until then i will be at my max(2.5gbps).
I'm very sorry that this didn't help you, this is the strangest thing, but for some unknown reason it helped me, yes, my speed decreased (when downloading something I just go back to 100), however, now I can play calmly. If someone wants I can record a couple of demos. I don't really understand this, but maybe it's somehow related to the packet buffer? If I go back to 100/1000/2500, it becomes impossible to play again.
make bufferbloat test
I did a lot of tests, tracing, buffer inflation, contacted the provider and checked if packets were lost, there were no problems by all parameters.
Panychkaaa
Post by Panychkaaa » 14 Mar 2025, 09:42
12 Mar 2025, 15:50
Everything turned out to be very simple, I am connected via FTTB cable, tariff for 100 Mbit/s. This method probably won't work for everyone, but it's worth a try. Go to the device manager - network adapters - select your network card - EEE Max support speed set to 10 Mbit/s duplex, also set the speed and duplex to 10 Mbit/s. Go to cs 2 or any other online game, try it.
Please write the result here, who it helped.
not work :!:
