you mean feel of your pc or about your life?
Window AC unit/Mini fridge schizo latency
- Slender
Re: Window AC unit/Mini fridge schizo latency
- Slender
anyway, if you've been playing with a bad pc for a long time, you've trained your muscle memory (even if your sensitivity is different every time for some reason). And you'll feel a change in gameplay when you change anything in the house, simply because a computer is a complex device that can be affected by literally everything, especially electricity.
Saphyen
Okay, I had an exposed wire on my cpu water cooler pump. Would this have done anything?Slender wrote: β15 Mar 2025, 19:13anyway, if you've been playing with a bad pc for a long time, you've trained your muscle memory (even if your sensitivity is different every time for some reason). And you'll feel a change in gameplay when you change anything in the house, simply because a computer is a complex device that can be affected by literally everything, especially electricity.
- Slender
if before all work perfect - yes.Saphyen wrote: β17 Mar 2025, 19:04Okay, I had an exposed wire on my cpu water cooler pump. Would this have done anything?Slender wrote: β15 Mar 2025, 19:13anyway, if you've been playing with a bad pc for a long time, you've trained your muscle memory (even if your sensitivity is different every time for some reason). And you'll feel a change in gameplay when you change anything in the house, simply because a computer is a complex device that can be affected by literally everything, especially electricity.
