I solved my problem finally
PewPew
Post by PewPew » 12 Feb 2025, 04:33
I changed my 12700K to 14700K
And the motherboard Z690 MSI Unify on Z790 ASUS E GAMING
DDR 5 Kingston Fury 6000 MHz did not change
It seems that the problem was in memory compatibility and processor
2 weeks passed. The flight is excellent, without delay. Gameplay in games very fast
I hope that I will never return to this forum again.
Thanks to everyone
Good luck!
DanGamesTwitch
Re: I solved my problem finally
Post by DanGamesTwitch » 13 Feb 2025, 01:30
Soon it will be am am am wait for Vasya’s grandmother with lard and a not smooth picture
MeveSPB
Post by MeveSPB » 13 Feb 2025, 05:07
I noticed that the new Asus has the ASUS Vanguard technology. Is this the solution?
"ROG engineers modernized the design with advanced signal-coupling technology and premium surface-mount components, which, add protection from power spikes and keep the (Gigabit) Ethernet signal cleaner, reducing the chance of errors. These are normally corrected by error checking mechanisms, but this requires CPU time that could be devoted to your game!"
DangerAhead710
Post by DangerAhead710 » 16 Feb 2025, 15:40
PewPew wrote:
12 Feb 2025, 04:33
Thanks to everyone
Good luck!
Is it still fixed bro? And what gpu?
PewPew
Post by PewPew » 16 Mar 2025, 09:55
DangerAhead710 wrote:
16 Feb 2025, 15:40
PewPew wrote:
12 Feb 2025, 04:33
Thanks to everyone
Good luck!
Hi!
No problems
ASUS ROG RTX 3080 OC
PewPew
Post by PewPew » 16 Mar 2025, 09:58
16 Feb 2025, 15:40
PewPew wrote:
12 Feb 2025, 04:33
Thanks to everyone
Good luck!
+ I replaced my ASUS TUF Gaming VG27AQZ 165 HZ monitor on LG Ultragear 27GS95QE-B
Mega smooth gameplay!
InputLagger
Post by InputLagger » 04 Apr 2025, 15:57
PewPew wrote:
16 Mar 2025, 09:58
16 Feb 2025, 15:40
PewPew wrote:
12 Feb 2025, 04:33
Thanks to everyone
Good luck!
Still fixed? Can you post all your hardware setup? With pc case, monitors and peripherals?
