Floaty Mouse - Input Lag (Intel 14600KF)
fjoecs
Post by fjoecs » 14 Mar 2025, 21:03
Hello,
I'm playing CS2 at a competitive level (10K+ hours in-game). About a year ago, I upgraded my PC to Intel 14th Gen and DDR5 RAM. After the upgrade, I noticed that my mouse felt floaty and less responsive compared to before.
Moreover, I played LAN tournament using the exact same devices, mousepad, and settings, yet the mouse on LAN felt significantly more responsive.
During my year of using the Intel 14600KF, I discovered some ways to improve mouse responsiveness. However, the problem has always persisted. The only changes that helped me slightly were BIOS settings:
  • Power Profile: Intel Baseline
  • C-States: Disabled
  • SpeedShift: Disabled
  • E-Cores: Disabled
Before applying these settings, I used to disable the XMP profile to improve mouse responsiveness, which helped significantly. However, after applying the BIOS settings mentioned above, enabling XMP no longer affects mouse responsiveness.
What also significantly improved my mouse responsiveness was uninstalling the Chipset Driver and disabling a few devices in Device Manager:
  • Intel(R) LPC Controller / eSPI Controller
  • Intel(R) LPSS: I2C Controller
  • Intel(R) Management Engine Interface
  • Intel(R) Shared SRAM
  • Intel(R) SMBus
  • Intel(R) SPI (Flash) Controller
The biggest difference could be felt after disabling Intel(R) SMBus and Intel(R) LPC Controller / eSPI Controller.
I've read numerous threads and forum discussions, where many people report mouse responsiveness (input lag) issues with Intel 13th and 14th Gen CPUs. Some suggest the problem is related to voltage, specifically System Agent and VCCIO.
I have a fresh and optimized Windows 11 installation, and my system specs are:
Motherboard: ASRock Z790 PG Lightning
CPU: Intel 14600KF
GPU: AMD 5700XT
RAM: Kingston DDR5 2×16GB (5600MHz)
Does anyone know how to fix this issue or further improve mouse responsiveness?
xShino
Re: Floaty Mouse - Input Lag (Intel 14600KF)
Post by xShino » 15 Mar 2025, 10:51
If you are like most people here, you probably won't find a solution.
That's why, in my opinion, you should first check if you can revert the issue by using your old parts again. Worst case, you will still have the issue. But if the problem is fixed by that, it might help finding the root cause.
dervu
Post by dervu » 15 Mar 2025, 11:41
Or just check again in other place if you noticed difference at LAN. Just check low hanging fruits first until you invest more.
Ryzen 7950X3D / MSI GeForce RTX 4090 Gaming X Trio / ASUS TUF GAMING X670E-PLUS / 2x16GB DDR5@6000 G.Skill Trident Z5 RGB / Dell Alienware AW3225QF / Logitech G PRO X SUPERLIGHT / SkyPAD Glass 3.0 / Wooting 60HE / DT 700 PRO X || EMI Input lag issue survivor (source being removed)
Post by Slender » 15 Mar 2025, 19:43
write your previous build:
psu, mobo, cpu, gpu, ram, ssd.
write all your current build.
fjoecs
Post by fjoecs » 15 Mar 2025, 20:24
Slender wrote:
15 Mar 2025, 19:43
Old Build:
Be Quiet! SYSTEM POWER 9 | 600W
GIGABYTE B550M DS3H
AMD Ryzen 5 3600X
RX 5700XT
CRUCIAL Ballistix 2x8GB | BL2K8G32C16U4B
Silicon Power SSD P34A80 512GB M2.NVME
New Build:
AsRock Z790 PG Lightning
Intel i5 14600KF
RX 5700XT
Kingston 2x16GB 5600MHz Fury Beast Black | KF556C40BBK2-32
Post by Slender » 15 Mar 2025, 20:33
fjoecs wrote:
15 Mar 2025, 20:24
ok, im see changes only in mobo / cpu / ram
i think you need to try make power cons on your 14600k like 3600x.
For do it you can disable ecores and HT.
ecores two ways:
bcdedit /set numproc 12 (set 6 if HT off)
disable via bios (can cause issues with wdf01000.sys, power off after pc on first time, etc.)
Disable HyperThreading.
Set your max turboboost freq, or just set x50 multiplayer (45 ring), you can leave voltage default, if it 1.1 or 1.2 max u can leave that or set manually. set AC/DC 1/1.
you need to reduce cpu consumption.
fjoecs
Post by fjoecs » 15 Mar 2025, 20:38
Slender wrote:
15 Mar 2025, 20:33
fjoecs wrote:
15 Mar 2025, 20:24
ecores two ways:
I'll try it. Thank you very much. By the way, I tried your mouse fix with device manager and it helped me as well :geek:
JimCarry
Post by JimCarry » 16 Mar 2025, 14:15
Slender wrote:
15 Mar 2025, 20:33
fjoecs wrote:
15 Mar 2025, 20:24
ecores two ways:
is this for his case or so can i do the same ? with amd pc?
Post by Slender » 16 Mar 2025, 19:42
JimCarry wrote:
16 Mar 2025, 14:15
Slender wrote:
15 Mar 2025, 20:33
fjoecs wrote:
15 Mar 2025, 20:24
ecores two ways:
yes, you need to reduce the consumption by half relative to your power supply
JimCarry
Post by JimCarry » 17 Mar 2025, 10:15
Slender wrote:
16 Mar 2025, 19:42
JimCarry wrote:
16 Mar 2025, 14:15
Slender wrote:
15 Mar 2025, 20:33
fjoecs wrote:
15 Mar 2025, 20:24
ecores two ways:
Thanks once again,i did have HyperThreading for amd disabled,but i did not have the bcdedit part so did it,the only thing left this:
"Set your max turboboost freq, or just set x50 multiplayer (45 ring), you can leave voltage default, if it 1.1 or 1.2 max u can leave that or set manually. set AC/DC 1/1. "
on intel mb / cpu there is option in bios called "AC" and "DC" right? but on my amd pc i dont know if there is such thing,and also the name for it.
the only thing i change in bios becides loading xmp profile #2 ,i change this in bios:
Setup Question = CPU Boost Clock Override
Token =99 // Do NOT change this line
Offset =AD
Width =01
Options =[00]Disabled // Move "*" to the desired Option
*[01]Enabled (Positive)
[02]Enabled (Negative)
Setup Question = Max CPU Boost Clock Override(+)
Token =9A // Do NOT change this line
Offset =AE
Width =01
Value =<200>
but if someone can explain,when i export bios via scewin it says it is like this :
Offset =AD
Width =01
Options =*[00]Disabled // Move "*" to the desired Option
Offset =AE
Width =01
Value =<25>
but the moment i enter bios it is enabled and its 200 how ?
