XG2431 Newbie help! (Fortnite / Competitive)
SleebySaya
Post by SleebySaya » 29 Mar 2025, 20:17
Hello,
(mind you, I'm a complete tech newbie, so I'm sorry in advanced if what I write below is stupid to you) :/
After trying around a thousand settings I lost hope. I just don't understand how to configure this monitor for Fortnite Competitive. I would really appreciate it if somebody could help me out with this one.
My specs:
RTX 3080 / 5800x / 32 GB DDR4-3600 / SSD
I cant get higher than 200 fps (stable) in fortnite.
The best result I got is when I used
Vsync: on
Monitor: 180hz
Ingame: Capped fps to 180
PureXP: Normal
I don't really know if these are the best settings, it just "felt" the best to me.
Guys, what settings would you use with the info given above to achieve least amount of input-lag and motion clarity?
Anything would help really.
wtjal3x
Re: XG2431 Newbie help! (Fortnite / Competitive)
Post by wtjal3x » 12 May 2025, 08:18
Yoo I can help you out for free just dm me on discord my username is , lalogaocaear7396 ,btw you should be getting more fps my old pc had a 5600x and 2060super it was pushing 1000fps looking at the sky and was holding 360fps stable during nitro season and 240 late stacked endgame so dm me.
