Longstanding Floaty Aim Feel Issue Fixed with a Fiber Optic DisplayPort Cable...
Hyote
Re: Longstanding Floaty Aim Feel Issue Fixed with a Fiber Optic DisplayPort Cable...
Bought the cable and it's a noticeable difference over the stock Zowie DP cable.
- Slender
Hyote
spkii
Hyote
If anyone is still looking at this as a potential desync fix, it isn't. Only buy it if you think your current cable has input lag / signal issues and you need something thinner and more flexible for your setup.
JimCarry
ok but ,if you have zowie and you see the diffrence between your stock cable and the dp cable you link from amazon,what if someone buys cheap aoc 240? then his dp cable is sh@t quality,i am thinking that when you buy monitor,cheap or expensive the dp cable is always cheap quality.
Hyote
I think it really depends on whether the company cares about the quality of cables. Like I mentioned earlier, the Nintendo Switch HDMI cable seems high quality, while most monitor cables are usually not. So AOC might have better stock cables than Acer or ASUS, regardless of not selling high-end products. These random Chinese cables can be risky to buy as well, because you can't find out if they got through any kind of quality checks and I haven't seen anything like fiber optic HDMI or DP mentioned anywhere else on the internet. For now I find it a good replacement for the inflexible laggy stock cable I had.JimCarry wrote: β07 May 2025, 15:20ok but ,if you have zowie and you see the diffrence between your stock cable and the dp cable you link from amazon,what if someone buys cheap aoc 240? then his dp cable is sh@t quality,i am thinking that when you buy monitor,cheap or expensive the dp cable is always cheap quality.
tattoo
got a dp and a hdmi both good quality,no difrence on my 480hz asus...also the hdmi goes black for no reason evry 10-15seconds
Coldplayer
Hyote
It feels like there is less input delay with the 2.1 fiber optic but it's barely noticeable. I also had problems positioning the monitor cable previously because of how thick and inflexible it was. I could put the new one further away from my PSU cable so that might be one reason. I have an XL2546.Coldplayer wrote: β08 May 2025, 04:50What was the difference over the stock zowie cable you got? Also which zowie monitor?
