EUREKA!
Vocaleyes
Re: EUREKA!
Post by Vocaleyes » 11 Jun 2025, 19:12
Here is what must be the 100th iteration of the app so far, there have been some crazy issues, but am at a point where it feels rather good and drifting has been drastically reduced. Enjoy!
https://drive.google.com/drive/folders/ ... sp=sharing
dermodemon
Re: EUREKA!
Post by dermodemon » 12 Jun 2025, 03:51
and how we can run these cpp files by the way? want to try it
Vocaleyes
Re: EUREKA!
Post by Vocaleyes » 12 Jun 2025, 10:47
dermodemon wrote: ↑
12 Jun 2025, 03:51
open folder - x64 - release - open app, should do it?
dermodemon
Re: EUREKA!
Post by dermodemon » 12 Jun 2025, 12:48
Vocaleyes wrote: ↑
12 Jun 2025, 10:47
dermodemon wrote: ↑
12 Jun 2025, 03:51
so i tested it. with this app running my desktop sensitivity feels like 3200 dpi instead of my 1600 dpi.
but in games - 0 differences. absolutely does nothing. only on desktop :cry:
Vocaleyes
Re: EUREKA!
Post by Vocaleyes » 12 Jun 2025, 13:58
dermodemon wrote: ↑
12 Jun 2025, 12:48
Vocaleyes wrote: ↑
12 Jun 2025, 10:47
dermodemon wrote: ↑
12 Jun 2025, 03:51
No problem, i've spent a lot of today working on all of this and trying to refine. I came across something interesting while doing this, which would fit the pattern of mouse on windows 7 was good, then went to s**t;
Windows 7 **did not** force vsync on mouse input at the OS level.
### Key Points:
**Windows 7**:
* Raw input, DirectInput, and standard WM\_MOUSEMOVE messages were all **decoupled from vsync**.
* Mouse input was processed **asynchronously**—meaning the cursor and input events were delivered immediately, not synced to the screen’s refresh rate.
* This is one reason why many users describe mouse movement in Windows 7 as feeling **snappier and more responsive**, especially in competitive games.
**Windows 8 and newer** (especially **Windows 10 and 11**):
* Introduced more modern input pipelines and compositor models (such as **WDDM 1.2+**, **DWM always-on**, **input injection** tied to frame presentation, etc.).
*Some input paths—especially those using `WM_MOUSEMOVE` or cursor drawing—became synced with the desktop compositor's vsync**, which introduced **input delay** (1–2 frames).
* Games using raw input or DirectInput often still avoid this delay, but the desktop and some UI frameworks now feel **slower** in cursor response compared to Windows 7.
Summary:
| Feature | Windows 7 | Windows 10/11 |
| Cursor tied to vsync | No | Yes (in many paths)|
| DWM always-on | No (can disable) | Yes (mandatory) |
| Raw Input delay | Minimal | Sometimes present |
| General cursor responsiveness | High | Often degraded |
So based on that information, I spent a lot of today trying to make it so that on windows 11 DWM vsync (which isn't disabled within nvidia control panel) doesn't affect mouse movement.
I made an app to reflect this.
Currently am boiled down to an app called "LowInputLagShell", this app;
✔ Reduce input latency
✔Bypass vsync-related delay
❌ Does NOT change mouse movement feel in any noticeable way.
What this does:
✔ Captures raw mouse input (via RIDEV_INPUTSINK)
✔ Skips Windows’ input-to-vsync sync via PeekMessage
✔ Uses high-resolution timers (timeBeginPeriod(1))
❌ Does not read or move the mouse cursor (no movement change)
❌ No processing or filtering added.
Please feel free to test this and let me know (find attached) am about to test it myself. Just getting it to a place where it's NOT janking out everywhere is the real challenge it turns out.
Cheers for the feedback!
Vocaleyes
Re: EUREKA!
Post by Vocaleyes » 13 Jun 2025, 19:12
Happy weekend everyone.
I have further improved upon the app "LowInputLagShell", by making another change.
I have made it so there's no more dialogue box that pops up when running the app, which is useful for testing but annoying when applying it practically. Therefore i have made the app run in "silent mode" which basically means in the background, then of course there is a secondary app made to terminate the app running in the background.
I am currently testing the app on a few different games, if anyone is interested and wants to try let me know and i shall share. Cheers!
xenvitsuFPS
Re: EUREKA!
Post by xenvitsuFPS » 14 Nov 2026, 19:05
Vocaleyes wrote: ↑
13 Jun 2025, 19:12
where can i get your tool? the google link is broken.
Hyote
Re: EUREKA!
Post by Hyote » Yesterday, 12:41
xenvitsuFPS wrote: ↑
14 Nov 2026, 19:05
Vocaleyes wrote: ↑
13 Jun 2025, 19:12
Here's the thing. The tool is probably trying to solve something that doesn't exist. What DOES exist however is Windows having mouse acceleration even with Enhance Pointer Precision off. Here's a picture of how it can be patched on 26H1. I'm probably the only tweaker who has it patched now in 26H2 across both my custom OSes.
Edit: forgot to credit fwf02 for creating this.
MontyTheAverage
Re: EUREKA!
Post by MontyTheAverage » Yesterday, 19:08
Hyote wrote: ↑
Yesterday, 12:41
14 Nov 2026, 19:05
Vocaleyes wrote: ↑
13 Jun 2025, 19:12
Where to download this
soul4kills
Re: EUREKA!
Post by soul4kills » Today, 08:29
Maybe it's not a windows problem. Is the problem because mice only have 1 sensor and can't track rotation. When you move your mouse, you apply a slight rotation to it. Is the slight rotation adding to the reports? If mice have 2 sensors, then it would be able to track rotation.
